0.75mm wheels spacers >
Old 12-14-2012, 09:13 AM
Conrad's Avatar
Default 0.75mm wheels spacers
Simple enough, who makes them? Thanks!
Conrad is offline
Old 12-14-2012, 12:30 PM
If you are talking about TC's , you can use any #6 washer from homedepot, steel or aluminum... I think hpi made them but they don't fit as well as the #6 flat washers....
bertrandsv87 is offline
Old 12-14-2012, 12:32 PM
Scottmisfits's Avatar
Tamiya makes a set of washes that goes between the hex and the wheel. They come in one pack with three different sizes. Not sure the part number though.
Scottmisfits is offline
Old 12-14-2012, 12:39 PM
Also 4mm flat washers will Work too. Dubro makes them . You will have to google it though....
Old 12-14-2012, 12:49 PM
MikeXray's Avatar
Trader Rating: 73 (100%+)
Xray silver ones are .75mm, TOP makes a full set of various sizes as well.
MikeXray is offline
Old 12-14-2012, 12:50 PM
Towerhobbies has the Dubro's and hpi(not a great fit)....
Old 12-17-2012, 08:04 AM
Conrad's Avatar
Thanks guys. After a quick search Xray (#305380) seem to be the only ones that actually make 0.75mm spacers and they come as a pack of two. The TOP and Tamiya packs come in different colours but they are all a mix of 0.5mm or 1.0mm. I can't find anything for hpi or dubro's.
Conrad is offline
Old 12-17-2012, 08:35 AM
The hpi and dubro's are just spacers that can fit but were not marketed for that purpose...
Old 12-17-2012, 09:19 AM
The Big Wig's Avatar
Want precision? Kose
The Big Wig is offline
Old 12-17-2012, 09:28 AM
sosidge's Avatar
The problem is that those Kose spacers will make the track width 0.1mm wider than desired. And that will cost you a tenth a lap.
sosidge is offline
