Tamiya TA05 Touring Sedan
#5806
Thanks for the info
#5807
just to show some pictures to the TA05 owners.....
if you think to install the mamba max esc, you might also choose the GM BL motor....... I've got it (GM 7,5T motor-3800kv) and it is a very good setup.......smooth and easily drivable, exceptional torque, now using with 6:1 final ratio
pic 2
pic 3
pic 4
pic 2
pic 3
pic 4
#5809
leomax001 - what upper carbon fiber set is that?
#5810
#5811
thanks... just checked them out. does anyone know if you can just buy the upper plate? on their site, it only shows it as a full carbon conversion.
thanks.
thanks.
#5812
Its not the 3 racing one. the 3 racing top deck is a whole piece and the spur cover isnt used. I know kawada do a carbon fibre chassis and you can aslo buy the top deck sepratly
#5813
#5814
Originally Posted by tw1st3d
looks like a tech racing upper deck
http://www.precisionrc.com/nv/car/pr...oduct_id=27626
...........exactly..........
#5816
Hi All,
Can anyone tell me what would be the best tire combination and the difference between compounds. The weather would be about 28 degrees celcius outside, not sure what the track temps would be. I have a problem where the car spins out off power, i have tried almost all setup changes i can, even running what the fast guys are, but they wont tell me what compounds they are using
Whats the difference between
Type A
Type B
B3
Which would be best to run in conditions mentioned above.
Does anyone also know of a good / cheap online shop that sells m03 spares ?
Type A
Type B
B3
#5817
Unless it is about 40 celsius outside, no reason to use B2 tires. I would go with the B3 compounds, but their life is short.
I was wondering if the direct center pulley from the 415 will work in the TA05? What do people use for the center pulley on an outdoor asphalt track and running a spool up front?
#5818
Hey guys,
I thought i would post a link to a video of a friend and I ripping his TA-05 up on a offroad track. The car acutally worked really well, it was surpising. After 4 battery pack and numerous crashes. All that was broken was a rear shock tower.
enjoy...
http://media.putfile.com/RC-Offroad-Touring
enjoy...
#5820
PLEASE tell me that TA-05 has a rally conversion!
