Xray T4 '13
#1471
Or actually I should say, what did you use to mount it? Thanks again.
#1472
#1473
After taking advice from on here I got a tornado fan myself. They call it tornado for a reason!
The best way to mount it is to use a servo post and screw the post in to the spare hole on the bulkhead. You can then just attach the fan to the post. Simple, effective, light and very secure!
#1475
Stupid question:
Does using 302525 instead of the plastic parts from kit affect the handling noticeably?
Also, has someone tried out the graphite a-arms and found the improvement in handling worth the money and time to install them?
#1476
I'm building my T4 and I noticed there is excessive play on the shock ball ends.
Just too much play for a touring car.
I miked the steel ball insert with a xtra one from a T12 and its the same.
It seems to be the plastics,the shock cap and the ball end.It also seems to fit T4 only.I guess its a fluke?.Must be a bad plastic mold?
I wanted to run the new car this weekend..Oh well
#1477
http://www.teamxray.com/t4/details/
It says:
"Both front are rear shock absorbers have front and lower ball joints by purpose larger to provide a little of play of the shocks once mounted to generate more traction."
It says:
#1478
The play is intended by Xray.
Quote from teamxray.com:
"Both front are rear shock absorbers have front and lower ball joints by purpose larger to provide a little of play of the shocks once mounted to generate more traction. "
EDIT: too slow
EDIT: too slow
#1479
It says:
It says:
I guess its optimized...
#1480
This may be a silly question, but in all my previous xray cars I told to drill a small hole in the top composite piece of the shock. Is that still a good idea with this car?
#1482
Thanks!
#1483
#1484
Building my first XRay.. what are those little brown square papers in each parts pack? Looks like sandpaper..?
#1485
