Like Tree2Likes
Xray T4 '13
Old 10-11-2013, 12:29 AM
  #5041
daleburr's Avatar
Originally Posted by hotrod1933
help
i have been running basically kit asphalt setup with.
21.5 blinky TC
2mm shims under inner links
2mm bumpsteer
kit springs and oil
1600 diff
droop ride height all kit
car is good on muchmore tyres 32,36 and really good on muchmore rush 36 and is ok on ride blue 32's
home track is medium to high grip
state titles this weekend and control tyres are ride rex34 but with carpet insert
temps low 30's celcius
track is again medium to high but more flowing with mid 15 sec laps.
first heat last weekend practise race all good then next heat snap loose on corner entry. tried second car and it is the same.
changed to rush 36 and car was good. so it is the tyres.
general feeling is i am overgripped in front as it is squealing a lot even last night when temps dropped. tyres are shredding and not smooth.
tried.
anti dive, less front camber 1 deg, more rear 3 deg and a bit lower ride height and it helped but was still not good.
then removed rear inner shims and bump shims and was a bit better but getting hard to drive.
car was ok quick for a single lap but would still snap out and spin if driven a bit harder.
then went to 2000 diff but was getting colder by then and really didn't notice
if better or not. everyone slowed a bit.
any suggestions. thinking of starting again with kit setup in first qual and go from there.
Try going thicker on your shock oil all round, say 450 or 500cst. This should calm everything down and remove steering, and look after the tyres more.
daleburr is offline
Old 10-13-2013, 10:45 AM
  #5042
Hi.
Anyone know what new parts is on the 2014? Should be posible to upgrade my 2013...?
Anthias is offline
Old 10-13-2013, 12:23 PM
  #5043
Jerz616's Avatar
Trader Rating: 49 (100%+)
Originally Posted by Anthias
Hi.
There will be a lot of parts to convert. New chassis , top deck, and the new arm mounts. I don't think you will be able to find all the parts to convert for a while. Even if you can it would prob cost you close to $200+ to convert it completely. Best to try and sell your '13 and put that $200 into a new fresh kit.
Jerz616 is offline
Old 10-13-2013, 03:53 PM
  #5044
AL1983's Avatar
Post Alu steering posts!
Hi,
Where can I find shorter alu steering posts for my Xray T4?
I know CSO fits but where can I buy one?
Are there other brands that fit?
Thx for replying.
AL1983 is offline
Old 10-13-2013, 04:06 PM
  #5045
nitrobeast's Avatar
Trader Rating: 46 (100%+)
Originally Posted by andrewdoherty
I've been building my shocks like this for a few weeks. Thought I'd share as I've had several people at my track lately ask me about building shocks.
http://www.youtube.com/watch?v=XlTXJ...ature=youtu.be
Ignore my goofs. I did it all in my first take and didn't notice I was saying o-ring instead of bladder and so on. I'm hoping it makes sense in context.
Great little vid! Thanks for taking the time.
nitrobeast is offline
Old 10-13-2013, 04:47 PM
  #5046
Odin544's Avatar
Trader Rating: 93 (100%+)
Anyone run boosted 17.5?
Odin544 is offline
Old 10-13-2013, 05:07 PM
  #5047
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Paul, thankyou for all the help with my car this weekend at IIC. My car was hooked thanks to you. Mr. Lemieux, you rock!
F. Mendoza is offline
Old 10-13-2013, 06:29 PM
  #5048
andrewdoherty's Avatar
Glad you liked it. I've been building them this way since January this year and haven't had any problems on the original o-rings and bladders.
andrewdoherty is offline
Old 10-13-2013, 07:35 PM
  #5049
Odin544's Avatar
So I have my car pretty close to ready for this next weekend, which is our first onroad club race of the year. Right now I am about 40g under weight though. I have the Xray 30g weight that goes in the middle under the belt, but would I be better off with regular lead weights at each corner instead? Car is very close to balanced L/R.
Odin544 is offline
Old 10-14-2013, 02:24 AM
  #5050
MrRolla's Avatar
Trader Rating: 30 (100%+)
Yep
MrRolla is offline
Old 10-16-2013, 01:57 PM
  #5051
Cloaked's Avatar
Trader Rating: 15 (100%+)
Hey Guys
I just picked up a 2nd hand T4 and will be running 21.5 blinky class.
I know I need an FDR between 3.00 to 3.5, so I went and ordered a 38t Pinion and a 69t Spur Kimbrough spur.
it was only afterwards I should probably ask one here haha, so what gearing should I be looking at for 21.5 blinky?
Sorry if this has been asked before I did a search for 21.5 but nothing specific came up.
Cloaked is offline
Old 10-16-2013, 02:15 PM
  #5052
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
With std/spec tires? 3.3-3.7
With us gt xpattern 3.6-4.0(large dia tire)
jlfx car audio is offline
Old 10-16-2013, 02:17 PM
  #5053
Jerz616's Avatar
Originally Posted by Cloaked
Hey Guys
That's all track dependent. I run 3.7 to 4.05 depending on layout. I would check on thst spur that you bought. The Xray's use an offset spur gear. Not to say that the kimborough wouldn't work but I have never tried one.
Jerz616 is offline
Old 10-16-2013, 03:03 PM
  #5054
Registered User
Thumbs up
If you make the Pinion Gear and Spur Gear with the curve gear mesh the center of gravity is divided from the front Spur and rear Spur. I think it will rotate at a constant level so good for cruzing there.
4JGR is offline
Old 10-16-2013, 03:07 PM
  #5055
hotrod1933's Avatar
Hey Guys
depending on motor and track.
anywhere from 2.7 on large tracks with some motors up to 3.6 on tigth tracks (riverstone)
i run from 2.77 to 3.25 same track different motors.
pm or post motor type and track you are going run at. also depends on how you drive. you can't always gear by temp either some motors will smoke even at 60c some get hot when geared to high as well (higher fdr)
hotrod1933 is offline
