Like Tree2Likes
Xray T4 '13
Old 05-27-2013, 02:25 PM
  #3796
aussierevo's Avatar
Trader Rating: 14 (100%+)
Originally Posted by yodace
Is there a place to read and that has pic off how to adjust and setup sway bars?
My rear sway bars when I move the rear arms up and down don't lift each other up?
Take a look at post #1789 on Page 120 and the few post following on that page of this thread and it provides a good solution to this problem. I had the exact same issue with the rear bar and found it was bend. Followed the steps detailed and problem solved.
aussierevo is offline
Old 05-27-2013, 03:37 PM
  #3797
Skiddins's Avatar
Originally Posted by chasingthepack
my next question is,i now have about 3.8 deg of toe in at the rear to keep the rear in check,this was with the ltcr other than using the speed 6 is there another way of getting the rear to not slide out off power at the end of the banked sweeper? that was the only way i could get it to grip,it hasnt affected the steering so overall the car should be faster,i wasnt checking lap times,the tracks grip came up as there were 5 of us constantly cleaning up the track,but even as the track cooled off it still made no difference to the handling,its the first time ive had the rear so good,im actually looking forward to the next meeting at wlrc
The LTC-R give good turn in, but sometimes you can use the Speed6 and get better lap times without it seeming to affect the steering.
I've been running the Speed6 at WLRC for the last few meetings.
Next time there I will most likely be running mod.
Skiddins
Skiddins is offline
Old 05-27-2013, 04:02 PM
  #3798
edhchoe's Avatar
Trader Rating: 41 (100%+)
Originally Posted by Johnny Wishbone
If you have a oversteer on exit problem with lite diff oil, reduce your rear toe.
Eliminating the sway bar is beneficial on tracks with really uneven rough surfaces as, even though a bar will flatten out a cars feel, if one wheel is bouncng more than another, the bar will transfer that over. Although this could be a indicator that you don't have the proper dampening or one weak shock as well.
Yes, the track is not smooth like carpet.
No rear sway bar maybe the correct solution for my car.
And why does Xray include 700 cst oil in the kit if 2000cst oil is what everyone prefers? Could Xray be wrong with their starting set up?
edhchoe is offline
Old 05-27-2013, 04:15 PM
  #3799
chasingthepack's Avatar
Skiddins
after running a mod motor today i was also contemplating it,its a shame they dont run mod at amcc,i love the acceleration,what a buzz
but wlrc could do with a boost to mod,very light on drivers
chasingthepack is offline
Old 05-27-2013, 06:27 PM
  #3800
Not wrong since my setup is probably different than yours at the same track, I don't know your track I'm just using it as an example. IMO it's a good starting point for most and that's what a box setup is for since everyone's driving style is different. I put 2000 in the diff and 450 all around out of the box and it was awesome. If you ask me the starting setup works 95% of the time and is real good and most don't go very far from there, if you ask me
JOE SI is offline
Old 05-27-2013, 09:03 PM
  #3801
CristianTabush's Avatar
Default New RSD Items
RSD107 RSD 11mm Soft Bladders (for T4 - 8pcs)
RSD104 RSD Motor Screws for XRAY T4 (2 flanged, 2 button head)
RSD102 RSD 1 degree Toe In Washers
RSD103 RSD 6mm Body Post Adjustable Body Holder
CristianTabush is offline
Old 05-27-2013, 09:37 PM
  #3802
What springs would you recommend from RSD?
I have all the option 4S xray springs
JOE SI is offline
Old 05-27-2013, 09:38 PM
  #3803
B00t13g's Avatar
Ordered some bladders. I'm looking forward to trying them.
B00t13g is offline
Old 05-27-2013, 09:59 PM
  #3804
Springs really depend on personal preference I have found.
With that said,
For Medium to Medium High Grip Asphalt, I like:
-Silver F/R and
-Silver F and Pink R.
For High Grip Asphalt I like:
-Blue F/R,
-Pink F and Blue R and
-Blue F and Black R
Ethan Erchinger just won the Open Modified Class at the Reedy Race using Red F/R with a 1.2 Sway Bar in the Front and no Sway Bar rear. The Red Springs are stiffer than the silvers.
On Carpet, most of the guys are running Blue and Black Springs.
This week we will also have a new spring to add to our asphalt spring set that will be softer than the silver spring.
Old 05-27-2013, 10:59 PM
  #3805
aussierevo's Avatar
when will the new spring set for asphalt be available online. I would like to invest in a set but if more springs are being added might be handy to wait. I run usually on low to medium grip outdoors.
Old 05-27-2013, 11:14 PM
  #3806
They will be available in 2-3 days.
Old 05-27-2013, 11:21 PM
  #3807
aussierevo's Avatar
thanks for that Cristian, I'll have my cart at the ready.
Old 05-28-2013, 07:53 AM
  #3808
bvoltz's Avatar
Trader Rating: 44 (100%+)
How do you tell if the front belt is slipping? I'm having a big problem with the rear passing the front of the car, acting like it is a 2 wheel drive... The belt nubs are in tack and when I hold the front wheels (with a front diff in) I have a lot of resistance, but I'm trying to figure out if the belt is slipping causing this issue...
bvoltz is offline
Old 05-28-2013, 07:56 AM
  #3809
artwork's Avatar
Trader Rating: 88 (100%+)
You can usually hear it clicking under braking if it is too loose.
artwork is offline
Old 05-28-2013, 08:04 AM
  #3810
bvoltz's Avatar
Thanks I will take a look..
bvoltz is offline
