Like Tree2Likes
Xray T4 '13
Old 01-20-2013, 07:53 AM
  #2446
Originally Posted by defcone
He's probably not running those 4 screws which stop the layshaft bearing from moving.
You are right.
Xray must close-up the bearings in the layshaft bulkheads, it is not difficult,
it is easy to do
eded1 is offline
Old 01-20-2013, 09:40 PM
  #2447
Trader Rating: 23 (100%+)
Default under dampened?
What are you all running for damping? My cars seems very soft, I'm dragging the chassis on both sides (5.2mm RH, carpet). I'm running kit springs 400 front 350 rear at the moment with 1.1 - 4 hole pistons. I'm thinking 500 all around, it'd also be nice to get a little more corner speed.
pcar951 is offline
Old 01-20-2013, 10:05 PM
  #2448
B00t13g's Avatar
Originally Posted by eded1
You are right.
it is easy to do
Like they did on the t3 12.
B00t13g is offline
Old 01-20-2013, 10:32 PM
  #2449
samnelso's Avatar
The car's fast when it rubs and, besides, I don't believe it's possible to fully prevent it. I've ran 400cst and 2.7/2.9 springs and she still rubed. Currently, I'm dropping back down to 350cst so my setup is more inline with the pro guys.
samnelso is offline
Old 01-20-2013, 11:25 PM
  #2450
Wow really, never had an Xray that dragged this much, I've gone through a can of motor spray this month just cleaning the chassis butter.
pcar951 is offline
Old 01-21-2013, 12:03 AM
  #2451
defcone's Avatar
Trader Rating: 15 (100%+)
I think Hara explained in one of his videos that no matter how narrow the chassis, it still rubbed so he stopped caring.
defcone is offline
Old 01-21-2013, 12:52 AM
  #2452
Losiho's Avatar
http://www.youtube.com/watch?v=Dluw3VUGYoU
From about 58 sec into the video.
Losiho is offline
Old 01-21-2013, 03:08 AM
  #2453
Trader Rating: 17 (100%+)
Anyone had issues with the shock bladders so far?
Went to reset my rebound and for some reason I can't seem to get any in them now
lethallee69 is offline
Old 01-21-2013, 04:45 AM
  #2454
defcone's Avatar
If you want rebound, you need to seal that hole in the shock top.
defcone is offline
Old 01-21-2013, 05:40 AM
  #2455
? I can get plenty of rebound without doing that.
Sean B. is offline
Old 01-21-2013, 06:22 AM
  #2456
Team EAM
Trader Rating: 79 (100%+)
They swell up in the shock once they have been in there with the oil. Some oils make the swell worse. It happens to all bladders. The new ones in the T4 seem to last longer than the old shocks though.
EA
EAMotorsports is offline
Old 01-21-2013, 07:02 AM
  #2457
Default O Ring on shock shaft
Are you guys running o rings on the shock shaft?? I have noticed all the Xray drivers not running their o rings on the shock shaft but oil leaks when I try to remove it. What am I doing wrong??
Serpenteer is offline
Old 01-21-2013, 07:37 AM
  #2458
porsche928gs's Avatar
That bottom o-ring that is in the bottom of the shock body, must be installed. It's an extra o-ring that people put on the shaft as a tuning aid to slow initial rebound and compression.
porsche928gs is offline
Old 01-21-2013, 08:13 AM
  #2459
Thanks for the clarification!
Also, does anyone have the explanation of what the different settings for the Roll center upper clamps?? Longer links vs shorter links?? I can't find it in the manual or setup books.
Old 01-21-2013, 08:27 AM
  #2460
Bigz84's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Adam B
Yes, longer links will make the car roll more. Here is a link to the directions for the new style upper clamps. I can't remember if the instruction manual was so detailed or not. I keep this in my pit bag and refer to it a lot.
http://www.teamxray.com/teamxray/pro...with Adj. Roll
If you use longer links you may need to play with your droop. Running low droop (high # on gauge) will counter act the benefit of the chassis rolling, IMO.
adam posted this a few pages back
Bigz84 is offline
