Xray T4 '13
#1516
Thank for the setup advice!
Here is my big concern. The rear diff. I have always run the xray ball diff which was way too easy to adjust. Now, with a gear diff it seems like more of a hassle to switch. I have NO idea what oil to run as our track is small, fast, and technical. I need to power out of the turns quickly and carry power deep into the turn if I want to stay with the leaders.
Traction is so subjective. What I find to be high grip others may say med. How do I tell if I have the rear diff set correctly? Just run the kit oil and be happy?
The carpet is an indoor carper, not an RC carpet.
#1517
I'd just run the kit 700cst. However, there are other setup things I'd worry about before the diff oil. 700 is a good start as the diff action will be very light and smooth and will help keep the car planted under power. Thicker oils, 2000cst or so, may start giving you a little onpower oversteer. Think of a locker/spool in the rear axle of a real car, when it's locked it's easy to do cookies, when it's not it will tend to push. Obviously, there's a grey area for everything though.
#1519
Dumb question, are diff oils and shock oils the same? Can I use a 40 weight shock oil that has a cst listing of 1000?
#1520
But I don`t think that 40 weight oil actually has a rating of 1000cst.
However, every brand of oil is somewhat different in weight even if the numbers on the bottle are the same.
Regards from Germany
#1522
#1528
