Team CRC Xti 1/12th Scale!! >
Like Tree221Likes
    Hide Wikipost
Old 03-02-2021, 05:42 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Team CRC Xti 1/12th Scale!!
Last edit by: tobamiester
Old 11-05-2012, 03:12 PM
  #466
theatriks's Avatar
Got home from work tonight and TADA it finallt arrived!....is there any tips or tricks i should know other then what the manual states before i start this build...thanks
theatriks is offline
Old 11-05-2012, 03:19 PM
  #467
Trader Rating: 64 (100%+)
Take your time with the front end. It takes some extra attention to get it loose and absolutely free without being wiggly jiggly. Especially the upper arms and shims. I had to sand the top graphite piece of the pod to get it to line up with the screws just right. Other then that it's a pretty decent build. Not many parts involved.
MC112b is offline
Old 11-05-2012, 06:45 PM
  #468
FaanP's Avatar
What MC112b said .... I had to take my front en apart and redo it. I took all the pins in the front end and polished them up with 1200 grid sand paper and metal polish to make sure the front end is 100% loose ....
FaanP is offline
Old 11-05-2012, 06:46 PM
  #469
FaanP's Avatar
Originally Posted by dontfeelcold
Sanding the diff rings? Really?
FaanP is offline
Old 11-05-2012, 07:15 PM
  #470
Trader Rating: 38 (100%+)
Originally Posted by bvoltz
The screw (per manual) does not fit into the hole of the Kimbrough 113 servo saver.
Any suggestion?
The head of the screw doesn't have to go into the hole. I just screwed it down as you show in the picture and it works fine.
linkless is offline
Old 11-05-2012, 07:16 PM
  #471
NolanP's Avatar
First - please forgive me, I'm very pissed off with this kit. Simply UNBELIEVABLE they can not include a servo saver (or one for each type), so I ordered the recommend one and the F%$King thing does not work.
Any suggestion?
Yes, I tried to drill it out, that did not work. I tried a standard 2mm screw...
If your fed up yet I will trade you for an xray X12....
So you can run mod
NolanP is offline
Old 11-05-2012, 07:26 PM
  #472
NolanP's Avatar
funny..... I will take a hammer to it, which we are VERY close to that..... VERY Close.....
My hammer doesn't work very well it has a working servo saver attached to it......
Offer is on the table if your getting sick of the XTI.
Hell I'll even throw in a servo saver and 2 servo's...1 of which being yours already
NolanP is offline
Old 11-05-2012, 07:32 PM
  #473
NolanP's Avatar
Really, sorry not trying to be a smart ass....
So if the Kimbrough 113 is the "recommended" per CRC, and this is the "normal" way to mount it (I will have to dig up a longer screw), then CRC, do you think it is asking to much to put this in the manual???
So what are other options for servo saver to run that really fits correctly?
Barry if you don't have your answer tomorrow I will hit up someone who runs the XTI and ask them which servo saver they run.
NolanP is offline
Old 11-05-2012, 07:50 PM
  #474
I rarely see anything other than Kimbro servo savers on any 1/12th scale. But you need to make sure you get the right one. The white one is for Futaba servos while the grey or off-white one is for servos with the Airtronics spline. As for the screw if you use a cap head screw instead of a button head it will fit down inside the servo saver. However I've had issues with the screw head pulling through the soft plastic of the servo saver so I don't go this route. Usually I use a longer screw with a washer to make sure it holds well. Those concave washers for counter sunk screws work really well and look pretty cool.
InspGadgt is offline
Old 11-05-2012, 07:57 PM
  #475
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Barry, give me a call anytime. I can walk you through whatever troubles you're facing in one call.
two 14 two 45 6651
AWD
andrewdoherty is offline
Old 11-05-2012, 08:34 PM
  #476
hairy's Avatar
I'm sure this has been answered somewhere in this thread but is the rear pod available separatly and if so what is the part number for it?
hairy is offline
Old 11-05-2012, 08:43 PM
  #477
Trader Rating: 19 (100%+)
http://teamcrc.com/crc/modules.php?n...prodID=7719438
http://teamcrc.com/crc/modules.php?n...prodID=7719441
http://teamcrc.com/crc/modules.php?n...prodID=7719437
http://teamcrc.com/crc/modules.php?n...prodID=7719440
http://teamcrc.com/crc/modules.php?n...prodID=7719443
these pieces are individual but all five together will give you the complete rear slider pod. What car are you planning to put it on? the mounting holes on the bottom are closer together then on an XL or and Xi pod so it will not work with either of those bottom plates and the new bottom plate will not work with the old main chassis because of the link mounting locations. Hope this helps!
-Randy
COLD AS ICE is offline
Old 11-05-2012, 08:52 PM
  #478
avs
avs's Avatar
the majority of kits do not provide a servo saver, i think because many use kimbrough's 'small' version which are brand specific (113, 114, 131, jr/airtronics/ko, futaba, hitec).
others prefer the medium version (201), the 201 is universal with different inserts, but it is a little oversized for 1/12 and will require a little grinding to fit.
you will rarely find anything but kimbrough, but i know one person that prefers the Serpent servo saver, it fits reasonably well and has inserts. i believe it is designed to be retained by a metric flat head screw.
if you have a JR, KO or airtronics servo then you should be good with the 113, just use a socket head instead of a button head screw.
avs is offline
Old 11-05-2012, 08:53 PM
  #479
This is how I do mine...the trick is finding a screw long enough to still thread into the servo spline.
Attached Thumbnails Team CRC Xti 1/12th Scale!!-servo-saver-1.jpg   Team CRC Xti 1/12th Scale!!-servo-saver-2.jpg
Old 11-05-2012, 10:18 PM
  #480
Slapmaster6000's Avatar
Trader Rating: 16 (100%+)
I don't bother sanding rings. I get the basic D ring, motor spray them off, install. Look closely at them, they are stamped out. Install them so they look like this: () not like this: )( I feel that the CRC 3/32" ball spur gear has the inner embossment molded too thick. It gets sandwiched between the diff hubs and makes the diff feel stiff without being tight. Shave one side down, preferably not the side that says CRC on it. Put the CRC stamp towards the motor side of the diff. Use #3363 (or was that #6636?) diff grease sparingly, don't flood the diff with it. Assemble the rest of the way per the instructions. If you want to get fancy, put in a Slapmaster Thrust Kit (plug,plug,plug). It should build up great and last a long time.
Some of those servo screws are 2.5mm. They are like gold. Don't loose them.
Brian
Slapmaster6000 is offline
