YOKOMO Touring Car BD-7
#5956
Thanks alot for the info EVOCHICK!! I raced USGT for the first time Friday. Foudn that we had to lower the FDR then what i was told. We started putting on smaller pinion gears. But that info is good to know. I was looking around liek crazy for my buddy.
#5958
But on my spare 14 car I just installed the rubber battery tape (B7-118RS) and prefer this to the holders on my 15 car. Its just easier to tape when your in a hurry and stops any battery movement.
#5963
Hey everyone,
What length are you adjusting the shocks to? I'm currently do as the manual says (63,5mm) but what effect will it have to make them shorter or longer?
Thanks for help
Thanks for help
#5964
On paper, I would think you shouldn't notice any effect at all if the shaft length still allows full arm travel after droop setting. If you shorten them more than what your arms are limited to, you're going to create strain on the shock because it will now be the limiting factor instead of the grub screw. If they're longer than what your arm travel allows it's pointless. Only possiblity I could ever see why you'd have to lengthen the shaft is if you ran out of travel and you still needed more droop, but that is offroad stuff where you're jumping and such.
Wierd things could possibly occur due to progressive springs though but I cant see how since the spring lengths aren't changing. Maybe someone with more TC knowledge can chime in.
#5965
Shock length can have an effect on "pack" as the piston position changes within the body. When the piston's neutral position (at static ride height) is lower in the body, there is a larger volume of oil above the piston. That tends to increase pack vs having a longer shock moves the piston further up the body which creates less.
I have been running 63.5mm as per the manual as well, but I can see lengthening the rear shock 0.5-1mm to get a little more rotation in the corner.
Something still on the list to test as I haven't been running a Yokomo for very long
-Korey
-Korey
#5966
Can anyone tell me where I can find a spring chart? Looked on petit rc and don't have it
#5967
#5968
Hey guys! Just moved from HB to Yokomo and I finished building my BD7 Black Series 2015 JMRCA last night. But I've come across an issue...with the JMRCA version I get the front DCJ upgrades that are 40.6 but when I put in the regular rear shafts (45.5) it seems that it's too long. I cant adjust the camber enough and seems like the shaft with the clip is really pushing hard against the diff. any help? Also when I tighten the spur gear screw that holds the spur gear to the chassis it seams to just make the gear stop moving. Is this a bearing issue? The bearing seems to work fine. really gotta get this all fixed before the big race! Thanks!
