Yokomo MR4TC-BD
#6916
Or Do what I DO... Switch to either Corally or the Cyclone.
The front is going to rub if you are using the alum knockle. you can either true the rim or shave some material down from the alum. knockle. I prefer to use the graphite knockle and shave the knockle down a little bit as it easier to do then alum..
The camber link ball cup is going to rub also, so you might as well change the ball cup to the sway bar ball cup style on the C-hub and rear hub side.
~Ming
~Ming
#6917
Trader Rating: 102 (100%+)
ball cup rubbing
the ball cup will rub depending on what height the chub is set at.
I use the CHub upper hole (outer hinge pin) never rubs the arm and helps make ride height easier, especially when using getting the most from the tires...i can run my tires down to 54mm.
I like to use the HPI heavy duty ball cups they don't rub...the RPMs are bit bulky and will rub the inside tire.
but as aozip mentioned you can use the sway bar open top ball cups they are pretty darn strong and won't rub.
#6918
Hi
I live in Britain, I got a BD in the winter season for running on carpet, I am planning to run it on a track at kemble airfeild in Britain.
http://www.cotswoldmodelcarclub.co.uk/
If anybody knows the track or has a look at their website above can see what it is like could give me a basic setup for the car. I am going to run a spool. the track is very very fast and smoth.
Also I was wondering what hop ups people recomended, as I belive i have some hop ups on the car as I have the white belts instead of the black ones I think i got some others as will.
James
James
#6919
Jamesd
What class do you plan on running at kemble I.E stocks, mod ?
#6920
Hi
I am planning to do 19turn
James
James
#6921
James, try cml distribution .there are several setups on there for the bd (std and grainger) with a couple of 19t ones from ian whittingham and andy robson i think. may even be a cotswolds one!
#6922
I tried CML but there are not really any on there which are similar to the track I am going on.
james
james
#6923
anyone have a starting point for a 3.5 novak brushless in the bd large open asphalt track, i don't have a brushed mod motor to go off of for gearing.
thanks
thanks
#6924
turtlemaster: 10.50 - 11.50 is the recommended gearing range for the 3.5 im using 11.20 in my BD. dont know the exact dimensions of our local track, but the fast guys lap in the mid 13's. for the first few laps, monitor your temp (both esc & motor) the ideal temp range is somewhere in the manual hope this helps
#6925
thanks.
#6926
Hi
Have just been to my local model shop and been told both my chassis are unusable. Due to graphit coming off and them breaking.
Does anybody know where I can get a cheap one from.
I would prefer ifsombody knew someone selling one in britain.
James
James
#6927
Originally Posted by Jamesd
Hi
James
James
#6928
james
james
#6929
Originally Posted by Chris Grainger
Hi All
I plan top post some pics of the CGM steering mod this week and explain what it does, there seem to be many questions about at the moment about various parts of the BD, I don't get on here as much as I would like, so please post some Questions for me over the next day or 2 and I will try to answer as many as possible
To reply to the Question above, the Kit roll bar is the "lower" roll bar the above one is one that goes over the top deck from the old MR4. We never use this any more.
Chris
Chris
Hi Chris, I know you are a busy man but do you have the info or pictures for the CGM Steering mod please..
