Yokomo MR4TC-BD
#5041
[QUOTE=Ali Graham][QUOTE=adyb]
I saw what i thort were white Rayspeed springs on Chris and Lee's cars?
Yup thats what they were! He also ran 400/350 oil (f/r), gold/silver roll bars and std front arms. Also with his modified steering rack and steering blocks, along with hpi c-hubs to gain more lock.
My car was awesome on Saturday running in the heat as the car was very aggresive but fast, but on the sunday when the grip was washed away (gay rain ) it wasn't quite there
Quick vid of it here:
http://s19.photobucket.com/albums/b1...ypractice1.flv
Can you please post a pic ot Graingers steering hub and rack mod.
#5042
Dont think their are any' but if their is im shure someone will know
#5043
Guys,
I'm just back from the track.
My mate runs a std BD and also a Grainger edition.....he has sheared 5 or 6 driveshafts when running a spool with both cars with a checkpoiint 7x1 motor.
I have seen it happen and he doesnt hit anything, at full revs on the straight the driveshafts just fail.....does anyone have any ideas as he's pretty fed up
Cheers.
Cheers.
#5044
I didn't take any pics, I thought the nosying was rude enough!!!
You can see the steering blocks on the pic of his car on this page: http://www.cmldistribution.co.uk/new...iew=0000000187
Basically, a hole has been drilled right in front of the std holes on the steering blocks, and the the special steering rack is further forward sot hat when the links are in this position, they are perfectly parellel, i.e at 90* to the chassis. I was told this is to achieve more lock. The hpi c-hubs seemed a straight fit too me
#5045
What part of the shaft is breaking? Yokomo had a problem with the stock pin in the universals being a little too short and we come loose and would give the appearance that it broke. I used a longer pin (the one from the Barracuda) and never had that problem again. Others have had the same issue and fixed it with a longer pin.
#5046
Originally Posted by Dan415ms
Guys,
Cheers.
Cheers.
#5047
Guys,
Cheers.
Cheers.
u need 2 keep on cheaking them after evry run or 2
#5048
#5049
Get the TiR CVDs. They are great, and will last. In a year we have only broke 1 axle (a hard hit into a board). The CVDs are showing very little wear.
Guys,
Cheers.
Cheers.
#5051
Guys,
Cheers.
Cheers.
Always check them before race day.
#5052
Originally Posted by rocketron
is he really shearing the Dog Bone? or the Pin?? If its the pin you can replace this with a piece of DRILL BLANK rod #53 in size just cut to size and it won't break the pin again
#5054
does anyone know what the differnce between running the
2.5 rear mount and 0.5 deg hubs and
3.0 mount and 0 deg hubs
2.0 mount and 1 deg hub
whats difference between in board and outboard toe in. how does it effect the car.
#5055
out board toe is the hubs
I can't remember which way round this is but I think outboard toe handles bumps better......plz correct me if its the other way round!
3 + 0 = stable steering, doesn't really like bumps
2.5 + 0.5 = best of the bunch really, very good steering, handles bumps pretty well, best of the bunch
2+1 = never tried this but it apparently gives lots of steering and likes bumps.
The 2nd choice is the best all rounder, on a perfectly flat, flowing track 3+0 is a safe bet
