Yokomo MR4TC-BD
#4561
Originally Posted by speedy-932
Hi,
I'm using the Excel delrin diff outdrives. They are working really well.
I'd like to have aluminium outdrives but there is no manufacturer who makes some.
Perhaps a new project?
Cheers
Chris
Cheers
Chris
#4562
Hi,
@rocketron: Great, if you're able to find out who makes them I'll be very interested.
Cheers
Chris
Cheers
Chris
#4565
Originally Posted by TOEBSTER2
Where can I get those from?
I think he may have some left
#4566
Hi,
@caveman: Yes, you're right. They are not expensive but I don't like it to have to replace a part more often then necessary. I would call it "perfectionism".
As long as I find parts on the car I don't like or which don't suite my sence of "perfection" I will try to fix them and to improve those parts.
@ZeroCooL: Have you tried Champ R/C?
Cheers
Chris
Cheers
Chris
#4567
Hi,
besides the fact that the Yokomo pins are snapping regardless which outdrives you're using, I wouldn't say that aluminium outdrives wear the CVD's out.
I made aluminium outdrives for the Alex Barracuda one year ago and had them in my car for 6 month before I switched to Yokomo. And I never snapped a pin, bent a dogbone or wear out a wheel axle.
So that's nothing I worry about. The only thing that is absolutely necessary are blades. But the ones from Xray are fitting really well (aswell as the one-way outdrives).
Cheers
Chris
Cheers
Chris
#4568
Hi,
Cheers
Chris
Cheers
Chris
#4569
Guys do anyone has the same problem?? my diffs loosen!!! What do you suggest to stop this anoyying thing??
#4570
are you running standard grease in them? also how tight are you setting them, and are you doing mod?
#4571
In my experience with the BD, I've found that the optional Team Losi Brown Diff Grease is excellent. It allows you to run your diffs looser without slipping.
#4572
Must agree with "team" mate Chris, the Losi stuff is pretty dailed
Chris whaddya mean "in your experience with the BD", you drive a JRXS!!!!lol
#4573
Hi,
@pops: Normally I'm spending my money and my time on things that make me faster and improve my skills. In my opinion that's a lot more worth then anything else. A new set of tires instead of new bling-bling-parts.
Just my thoughts on this.
@Zacharopoulos: Have you tried a new screw and a new lock nut?
Cheers
Chris
Cheers
Chris
#4574
Guys i am running with brushless , LRP Sphere comp and 4star , about 62.000 rpm !!! I use the standard grease , and i set them very loose , and then after i saw that they were slipping , i tight them , i could say that i tight them very much , without huring the rings or the diff balls , but it also loosen
#4575
@speedy : yeap , i also noticed that yokomo , has a strange screw ( a little slant ) but doesn't fit our diff!!
