Yokomo MR4TC-BD
#2057
Originally Posted by Hebiki
can someone explain bump steer? i keep getting different explanations for it.
#2058
Originally Posted by Matt Howard
Bump steer is the angle the wheel moves when the suspension is compresses. If you turn full lock on the BD, the wheel wants to bump out slightly. This gives you better corner speed but hinders the turn in steering. By flipping the steering turnbuckles to the bottom of the graphite plate (still put the spacer between the ballstud and the plate), you're altering the bumpsteer slightly so the tire doesn't bump out as much, giving the car more turn-in steering.
sweeeet. thanks matt.
#2059
Originally Posted by highwayman
that's right... forgot about that... im very happy with the TC4 bones with rayspeed MIP axles... maybe i'll just get them for the rear...
are you running them in the front? haven't installed the front ones yet.
#2061
Originally Posted by rc-zombies
I tried the TC4 bones/RS axles in the rear...doesn't fit..bones are too long...
Yes, im running them in the front... i never tried them in ther rear, im using the stock rear axles, with the blue alm yoke bones in the rear.
i installed the TC4 bones a week after i got the car, (maybe 2nd week of april), been running the car with a front 1 way and we usually run twice a week, around 5 to 12 packs per day... so far, there is no visible wear on the bones... but i did notice some polishing of the TC4 bone where it contacts the steering knuckle, so i polished the innner portion of the stock knuckles.
in my opinion, this is the best option to use in front, in terms of durability, looks, and wear.
#2062
Hi Matt... is there another way to get bump-in steering without having to flip the turnbuckles...
why would the stock setting of the turnbuckle give more corner speed, if it actually bumps out during full lock?
#2063
Since the stock setting bumps out slightly, when the car corners hard the outside wheel will want to straighten slightly keeping the cars speed up and not scrubbbing it to make the corner. I'm talking about really small changes in the steering angle here, nothing major, just turn the wheels on your car and compress the suspension and you'll be able to see how much bumpsteer I'm talking about. It's just another small tuning option that myself and some others use.
#2064
Guys, mind giving me the part numbers for the TC4 bones and the rayspeed axles? Wat's a good online shop for rayspeed stuffs? Thanks.
#2065
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
rayspeed spring sort
any of you yokomo/rayspeed fanatics got a spring guide for rayspeed springs & what poundage they are from soft-hard
cheers big ears (in advance)
i have been out of the loop for awhile so need bringing back up to speed
(been in the `dark side`)
#2066
Spring Rating [lb/in]
Orange 18.87
Green 16.06
Pink 14.93
Yellow 14.71
White 12.94
Blue 12.12
Rayspeed
Gray 19.90
Red 18.26
White 17.17
Yellow 14.87
Blue 14.29
Green 13.20
#2067
BTW, Matt... thanks for the explanation. It definitely helps to know how the steering angles will affect setups. Thanks again!
#2069
Originally Posted by Chrissy C
While we are on small changes made to the steering could you please tell me what moving the ball joint forward on the graphite steering plate will do (stock setting is 3rd hole back out of 4 i believe)
Cheers
Chris
Cheers
Chris
