Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 11-08-2006, 04:41 AM
  #6046
AngryAsian's Avatar
Originally Posted by raceblast
Why are there different purple alum front pivot ball mounts (1,1.5,2,2.5) on the cyclone and pro4? How do they affect car handling?
The inboard toe block affect how the car drives into a corner. More toe out means the car changes direction quicker, and also has more front end bite.
Personally I've only ever used the 2.5deg block. So I can't comment on how it affected my car in relation to the different tracks I run at.
AngryAsian is offline
Old 11-08-2006, 05:37 AM
  #6047
Phil C's Avatar
I have always found that...
More inboard toe out = More initial steering (into corner) less mid to exit.
Less inboard toe out = Less initial steering (into corner) more mid to exit.
Hope that helps,
Phil.
Phil C is offline
Old 11-08-2006, 07:22 AM
  #6048
John Doucakis's Avatar
Just installed my new brushless.
It's a tight fit, but this will not be a problem for too long, as I will run it with 6 cells just to see how scary fast it is and then it will be always run with 5 cells as per the new European (EFRA) rules, so I will try different electronics configuration.
John Doucakis is offline
Old 11-08-2006, 07:33 AM
  #6049
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Hi John,
Nice pics. Just wanted to know where you got your Orion Brushless System from???
Thanks.
Leonard.
DirtyDog3375 is offline
Old 11-08-2006, 07:37 AM
  #6050
Turbonium's Avatar
Trader Rating: 27 (100%+)
Originally Posted by DirtyDog3375
Hi John,
Thanks.
Leonard.
i have an idea...
lets not quote possibly the largest pictures of an rc car on the forum.... j/k!
nice pics, as always, John.....
Turbonium is offline
Old 11-08-2006, 07:38 AM
  #6051
Hi John,
Thanks.
Leonard.
Thanks Leonard.
First of all, please edit your post and delete the links of my pics, so you avoid making huge posts.
I just happened to be at the right place on the right time. It's still hard to get. Also the sticker is made by me.
Old 11-08-2006, 07:39 AM
  #6052
Sorry about the large post. All fixed now.
Old 11-08-2006, 08:44 AM
  #6053
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Here are my Cyclones , one for carpet the other a Hara for asphalt
Marcos.J is offline
Old 11-08-2006, 10:05 AM
  #6054
[QUOTE=Marcos.J]Here are my Cyclones , one for carpet the other a Hara for asphalt
Which brand are those yellow springs?
benoitrdv is offline
Old 11-08-2006, 10:20 AM
  #6055
nf_ekt's Avatar
Trader Rating: 115 (100%+)
Hey Marcos is the other car an "S" version? Is it converted? (he-he little inside joke )
nf_ekt is offline
Old 11-08-2006, 11:33 AM
  #6056
Super Moderator
Marcos.J's Avatar
[QUOTE=benoitrdv]
Tamiya's
Marcos.J is offline
Old 11-08-2006, 11:41 AM
  #6057
bxpitbull's Avatar
talk about a stab!
bxpitbull is offline
Old 11-08-2006, 11:59 AM
  #6058
nf_ekt's Avatar
It's all for fun. Marcos you should post the mod you did for the front spool, looks pretty good.
nf_ekt is offline
Old 11-08-2006, 12:00 PM
  #6059
Super Moderator
Marcos.J's Avatar
Maybe we will keep that secret to our selves
Marcos.J is offline
Old 11-08-2006, 12:13 PM
  #6060
nf_ekt's Avatar
Sho-nuff
nf_ekt is offline
