Hot Bodies Cyclone
#5821
Originally Posted by bjspinner
This is mod that I am running Marcos the 3.5 is fast, I felt like I needed a bit more steering out of the corners Jason.
I feel you are saying to control the roll use droop not harder springs.
Hey Marcos where you using 3.5 rotors in the 4.5 & 5800 if so how did they go. ie power and braking as there is a big difference in brakes with the 3.5.
its not necesarily controling the roll,its controling weight transfer and getting the balance of traction you are looking for.for more initial steering i add more uptravel in the rear,for more on power steering decrease front uptravel and so on.i change it for almost every track i run on with given conditions.i dont change much on the rest of the setup.you want the car to roll and roll evenly for a smoothe feel.if you want more side bite at either end of the car you can move the shock location on the tower further out for a more verticle position.you will get it working buddy,it just takes a bit of fine tuning.
#5823
Originally Posted by moot
anyone got a half decent set-up on concrete using cs-27's? the track is a little bumpy and tight-ish
anyone? i cant get it to 'work'
#5825
Originally Posted by L.Fairtrace
Ran my BMI cyclone on the rug tonight with 6 of the top 20 at the IIC in stock and it was awesome. Had 8 packs on the car and was tq after the first round. Its a good setup for med-high bite rug. Ran a different setup than scheffler did at the IIC, if anyone wants to try it let me know. I have to make a setup sheet.
The car is sick, I definatley think its my favorite touring car to date.
#5829
Originally Posted by bxpitbull
But of course.
#5832
I'm pretty sure that the pin size is the same, just that the Pro 4 drive shafts are a few mm longer than the Cyclone ones.
#5834
To those interested in aluminum outdrives for the Pro4
Send me an IM and I will reply with my contacts email address. Ensure that you mention me so he knows where the email came from. And no, I am not getting a kickback. I am paying $31 dollars a set just like everyone else.
#5835
Anyone have an editable setup sheet. I'll get to work if you do
Come on Larry Hook me up with the setup!. I got my Cyclone chassis comin in this week!
