Hot Bodies Cyclone
Main belt on my cyclone tc is really loose just pulled the front diff out and it looks fine does anybody know how to fix this problem?
adjust the bearing holders - the hex-ish shaped thing that the bearing sits in, don't know off the top of my head which way will make it get tighter, but you can play with it to see the looseness go away
Suspended
ok guys i have a question
what effect does that little piece of foam above the bladder have on how the shock works
compared to not using it
compared to using an oring above the bladder
my front wheel chatters when steered left or right. i'm using MIP CVD now.
is there a way to correct this other than the DCJ part?
Help
Hi all
Im running this setup & i'm chasing a bit more corner speed & corner exit steering .
http://www.hotbodiesonline.com/pdfs/...ning_Setup.pdf
Only changes i have made is 5.5mm RH front & 6mm RH rear / 4.5mm downstop all round & rear shock moved up 1 hole on top .
Running Sorex 28's & Exotek lipo chassis .
Track is low grip .
Should i change my front droop / rear swaybar / rear springs / oil ?
Any help wouls be great .
Track is low grip .
Hi all
Track is low grip .
Track is low grip .
at my local track i run 4.8mm front 5.2mm rear and have awesome corner speed compared to running 5.5 and 6 which i used to run with the original chassis.
a small quick change u could make is lowering ur ride height. with the exotec chassis u can run much lower ride heights. for starters try 5.0mm front 5.5 rear. even lower if ur track is not to bumpy.
The problem i have is the chassis already scraps near the down stop screw on the rear ( track is bumpy )
What down stop do you run with that ride hight ?
I think i need to go up a spring in the rear ( run silver frt & rear ) or maybe run silver swaybars frt & rear , maybe lift rear shock up a hole on top .
Any thoughts
Hi
Any thoughts
Any thoughts
5.5mm F and 6.0mm R ride height
3.0mm droop in front 2.0mm in back
1.4 F 1.2 R sway bars
3 hole pistons
kit springs all-around
50wt oil in front 45wt in back
stock foams in shocks 75% rebound
shock position 3 on all corners
2.0 front toe block
3.0 rear toe block
1.5 shims under FF FR RF RR toe blocks
1.5 mm shim under F camber link
1.0 mm shim under R camber link
1.0 degree toe-out front
1.5 degree negative camber all-around
everything else stock
track temps last race was 144+ degrees
sorex 40R
this is permanant track in Hawaii
New parking lot setup of mine. so far it's been pretty decent wherever I go! I forgot to add in the notes... add a .5mm spacer on the steering ballstud on the steering knuckle.
-Korey
-Korey
Korey,
I have noticed the tamiya guys use a lot of antidive in front, do you feel that works for the Cyclone too?
I think in modified it can help. It keeps the front end from diving so much under braking which seems to make the car a little more stable to me.
-Korey
-Korey
Hi Korey,
What do you think of the EXP36 tires compared to MM and Sorex?
I just tried the MM32_Absolutes for the first time (was Sorex36) and the car is like it is on rails.
Cheers
Cheers
They are pretty similar to sorex. I feel on the first run they are faster than brand new sorexs... but after that they feel pretty equal. I remember running the MM absolutes when I ran for Much More in the past. They work really well too, but justg about any tire worked at the track I ran them at. It was a super high bite indoor asphalt track that made any tire really good!
-Korey
-Korey
Any chance of a better pic of that setup sheet ? ( can't read the full settings )
Or can you just write the setup on this
