Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 01-09-2010, 04:55 AM
  #18196
Originally Posted by cherry2blost
Loosen ALL the screws that go into METAL (on topdeck AND underside of car) just 1/2 a turn or so then grab the front and rear, give it a bloody good twist left to right and then right to left, fixes most of my problems except bent alloy parts (change em).
Cheers!!!!
My lipo's were going to be about half way across the atlantic to get that balenced!!!
Sorted now, I was just been to soft.
cheers,
michael.branth is offline
Old 01-09-2010, 05:41 AM
  #18197
Super Moderator
charlie_b's Avatar
Originally Posted by padillo
Hi cyclone friend
i have few question
1. what suitable ratio range for my cyclone (2.4375 FDR) if i use 3.5T motor (for use in asphalt large track)?
2. for one way 18t centre pulley, which side i have to put?..both one way?
thanks
1. Start with a 9.5 and go from there.
2. You put the center one way on the left side of the shaft if the car is facing AWAy from you. Basically you put the one way on the long belt.
charlie_b is offline
Old 01-09-2010, 06:54 AM
  #18198
ok thanks buddy..i'll work it out
padillo is offline
Old 01-09-2010, 11:25 AM
  #18199
STLNLST's Avatar
Trader Rating: 32 (100%+)
Check your pm's
STLNLST is offline
Old 01-09-2010, 02:51 PM
  #18200
mlight13's Avatar
Trader Rating: 40 (100%+)
Originally Posted by thejo3
TowerHobbies now set the Sport version Kit or RTR, as discontinued.
Anyone knows if HB will remove car from sales or just Tower won't offer it anymore. (TC is still available though).
I just ordered my Cyclone S with a Mazda body. I asked the manager why they are being discontinued and he told my only the ones with the Stratus body are discontinued which come in the kit and RTR versions. The kit without the body and the kit with the Mazda body will be around for a while. That's good news for me and others wanting parts support in the future.
mlight13 is offline
Old 01-09-2010, 02:56 PM
  #18201
cherry2blost's Avatar
Good that's just as well because I truly believe that the 'S' is the ideal platform for newbies to start out on, less fragile than a Tamiya and perfectly adequate for racing as well as bashing. Add the hop ups as and when and you got a fully fledged race car on your hands.
cherry2blost is offline
Old 01-09-2010, 04:55 PM
  #18202
Riketsu's Avatar
Trader Rating: 34 (100%+)
Hey guys, what FDR should I begin with for my Cyclone WE?
The track is medium sized and on carpet. I will be running a 10.5 X12 with Lipo.
Thanks.
Riketsu is offline
Old 01-10-2010, 03:09 AM
  #18203
Thanks.
hi
i think cyclone WE FDR same with cyclone TC which is 2.167
it depend on your pinion and spur ratio..you can create your gear ratio chart at gearchart.com
cheers
padillo is offline
Old 01-10-2010, 03:15 AM
  #18204
hi cherry2blost you got PM
padillo is offline
Old 01-10-2010, 03:30 AM
  #18205
Not yet I ain't lol
Old 01-10-2010, 04:07 AM
  #18206
hi all friend
is it the higher ratio number give more torque than lower ratio number?
can anyone clarify this?
thanks
padillo is offline
Old 01-10-2010, 04:09 AM
  #18207
speedzer's Avatar
new to HPI and hotbodies products.
how do u guys differentiate the spring rate of hpi springs ?
- i see them label in coils. so does that means more coils is much more stiffer ?
speedzer is offline
Old 01-10-2010, 04:20 AM
  #18208
Hope this helps, it is done on 'weight' of springs.
Old 01-10-2010, 04:22 AM
  #18209
hi all friend
thanks
Are we talking about gearing, or motor wind?
Old 01-10-2010, 04:36 AM
  #18210
RC MARKET's Avatar
also use White Gold Pink Silver Blue only !
RC MARKET is offline
