Hot Bodies Cyclone
-Korey
Trader Rating: 20 (100%+)
Now if this makes any real noticeable difference in "pack/dampening" I don't know.
Can't remember if you were around when we released our lipo bulkhead and top deck option. We also released some aluminum rear hub carriers in 0 deg (same as plastic ones) and 1 deg for further tuning options. HB also released a new body, a Subaru Impreza. It's a very good body that feels like a cross between a mazda 6 and a mazdaspeed 6. DCJ's seem to be the most popular of all those new option parts though.
-Korey
-Korey
Korey, would you have part numbers for the hub carriers ?
Also, I have two steel CVD axles assemblies. They are black and the axle piece has the cup and the dog bone has the slotted ball. I believe they came with my first black Cyclone or were an option for it. How many steel cvds has the cyclone had ? Do you have any part numbers for the black cvds ? What do you use ?
Thanks for your time.
Aluminum rear hub carriers (1 deg) - 67696
Aluminum front spindles (have a new hole for more ackerman adjustment) - 67698
I use the Purple MIP CVD's up front usually. In the rear I use the purple ver 2 aluminum universals.
As far as I know... I think there were 2 different steel universals. One that followed the design of the ver 1 universals (smaller joint) and the ver 2 with a larger joint. I could be wrong about this though, I'll ask Hiro if he can pop on and answer for us.
-Korey
Korey,
Thank you for all of the info. I am a New Cyclone Owner. I have been spending a lot of time re-reading all of the past posts. What is your input on the Cyclone on the rug?
Dave
Dave
-Korey
Psh... I'll probably be up till 3AM reading a history book... I saw the changes and they make sense. I'm glad they worked out for ya!
-Korey
-Korey
korey - what's the results of using the non-TC shock towers on a TC chassis?
Changing the overall shock length will change the position of the piston inside the shock body. A longer shock (eyelet turned out more) will result in the piston being raised higher toward the bladder during compression. A shorter shock (eyelet turned in more) will lower the position of the piston.
Ballistic - Dont worry about it man. I just use 64mm because thats what Hara and Andy usually always start with. As far as I know, they almost never mess with it much anymore.
-Korey
-Korey
-Korey
Korey
thanks. Lipo bulkhead not needed as I've dremeled the stock one years ago already. Top deck, bah... Alum suspension parts I leave to noobs hop up'ing TT01's, and I still have a few bodies (M6, M6speed, Strat3) that need to be thrashed before they're trashed... DCJ's look yumyum but they aren't cheap and I still have a stock of CVD's....
Which means I'm good to go woo-hoo!!!!
Thanks for the input,
Paul
