Team Orion Advantage Charger
#287
so you should start at the minimum voltage to have the maximum amps available.
#288
I had a problem just like that with the motor run-in. @ 2 volts the charger stopped, but @ 7,2 it worked. The problem was that my powersupply was set at 14,5 volts, but at 12 volts everything worked as usual.
#289
Great information thanks
#290
I need some baseline help. I will start using my Advantage tomorrow night and dont want to have watch my charger like a hawk on my batteries.
I have always used between 20 to 50mv setting on my T35GFX for my batteries. What is the equivalent setting for a 4-cell pack and a 6-cell pack as the Advantage is rated at /cell. I want my GP3300's to peak no higher than 130 deg F and my IB3800's to peak around 125 to 140 deg F max.
Also-any tricks or dos and donts with this that could ruin a battery pack or really make a pack scream? Anyne prefer a Mah or temp cut-off over using a delta peak and also-any tips on how to combine these to safegard a pack? Lets say its set at a delta peak value AND a temp cut-off or Mah cut-off? How do you recommend this be done?
Thanks,
Ray
Thanks,
Ray
#291
Thanks,
Ray
Thanks,
Ray
Just use the same mV/cell setting whatever number of cells you charge. I use 3mV/cell, which equates to 18mV delta on a 6-cell pack or 12mV delta on a 4-cell.
The charger works out what overall delta to use based on the charging profile, i.e. how many cells you tell it it's charging and what delta per cell to use.
I always use the temp cutoff as well. I tend to use the first (7A on ours) portion of the step charge to give the packs a final kick before a race, cutting off at around 32 degrees C.
Hope this helps.
#292
Also the latest setup are on the Team Orion FAQ, including Hara's from the Reedy Race
#293
Originally Posted by EVOtech
Ray,
Hope this helps.
Hope this helps.
#294
All went well on the first night with the charger. No suprises, but I am wondering about the thermal shut-off. I had it set at 50ºC, but I think the unit was shutting off on delta peak after 50ºC was achieved.
I read the instructions, but I am not clear if delta peak takes precedence over temp and/or how to make it peak on temp instead.
Thanks,
Ray
Thanks,
Ray
#295
Thanks,
Ray
Thanks,
Ray
the temp, peak, mah settings will stop the charge when any one is reached.
#296
Originally Posted by rocketron
hi ray, i use this charger and what you maybe seeing is the peak detection cutt-off at 49 or even 50 but by the time you checked the temp it had risen. the temp reading doesn't stop at the end of the charge.
Ray
[email protected]
#297
Ray
You have mail!
Later,
Later,
#299
Any place who has them in stock ?
