Tamiya F104 Version 2 >
Like Tree2Likes
Old 07-03-2012, 10:50 AM
  #151
R/C Tech Elite Member
JayL's Avatar
Originally Posted by Vyger
That would probably work better than the stock set up. I just wanted something smooth and interference free. I don't think the carbon plate will break because of the countersinking...but I guess anything is possible if hit just right.
Understood
I think I will try the button head and if it rubs etc , on my 'non shelf queen' , during racing I will stick with that
Really like all your pics and input, thanks!
JayL is offline
Old 07-04-2012, 07:57 AM
  #152
Hello, just ordered mine but forgot to order aluminium motor holder...
I've ordered only Ver2 itself, without any hop-up parts as a replacement for my old f104 pro...
question is, which hop-up parts do you suggests? :-)
(rcmart.com doesn't even have the aluminium motor holder... I think that I need to find another seller...)
P.S: do you have any advice for a seller of hop-up parts for ver2? (near central Europe)
SquirrelCZE is offline
Old 07-04-2012, 08:00 AM
  #153
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Check out the article from my sig
Has tons of info about the VII
RedBullFiXX is offline
Old 07-04-2012, 08:07 AM
  #154
R-Sector's Avatar
If you guys are not in a hurry, you can consider this
Heres our prototype of the RRS for F104V2/RM-01, it figures an extended motor mount which makes the shock tower shorter therefore a stiffer structure over all for the shock to work more efficiently. Two wing mounting positions for more downforce when needed.
R-Sector is offline
Old 07-04-2012, 11:06 AM
  #155
flyingm's Avatar
Default New body from McAllister Racing
New Product Release from McAllister Racing-
#291- 2012 IRL body, 1/10th for Tamiya F104 chassis’. One piece body. The IRL made a drastic change in the looks of the Indy Racing League cars for 2012. McAllister Racing leads the way in scale racing trends with this latest IRL body for the Tamiya Formula cars. Great for Oval or Road Course. Uses the stock nose wing from the F104W kits and the stock body posts.
Pictured on an F104W.
All McAllister Racing products are 100% made in the U.S.A.
Please support your local RC dealers and ask for McAllister Racing by name.
Attached Thumbnails Tamiya F104 Version 2-291-2-irl-2012-copy.jpg   Tamiya F104 Version 2-291-4-irl-2012-copy.jpg   Tamiya F104 Version 2-291-6-irl-2012-copy.jpg   Tamiya F104 Version 2-291-14-irl-2012-copy.jpg   Tamiya F104 Version 2-291-11-irl-2012-copy.jpg
flyingm is offline
Old 07-04-2012, 11:19 AM
  #156
texastc's Avatar
O
M
G
Thanks!!
texastc is offline
Old 07-04-2012, 09:14 PM
  #157
Hi Guys..
Just try my f104 v2 yesterday...
I wan using all soft spring and tamiya rubber tire on carpet...put tire traction both front and rear...
I was having a lot of fun...
but having a bit problem with diff....its seem a little bit to tight but when i loss it, it to loose...
so you guys recommend on using 1 trust bearing from f103...and 1 question regarding counter weight on x1..will it be possible to use on v2? because i see its different type of axle..
Hope you guys understand..
k4mp4q is offline
Old 07-05-2012, 01:16 AM
  #158
dfx
dfx's Avatar
Originally Posted by R-Sector
Heres our prototype of the RRS for F104V2/RM-01...
Looks nice!
Originally Posted by k4mp4q
...so you guys recommend on using 1 trust bearing from f103...and 1 question regarding counter weight on x1..will it be possible to use on v2? because i see its different type of axle...
I have no experience with V2 diff yet but one piece trust bearing works well with older Pro diff (for me)...
If You want to use counter weight You will need short wheel stopper, not the Clamp Type Wheel Stopper from the V2 kit. Here's a picture of the counter weight with R-sector wide track kit but it'll be the same with Tamiya wheel stopper.
dfx is offline
Old 07-05-2012, 03:18 AM
  #159
Originally Posted by dfx
Looks nice!
Thx dfx....
Other thing is what spur and pinion should i use for track that have 25m staright...i'll be using brushless 17.5
k4mp4q is offline
Old 07-06-2012, 06:40 AM
  #160
wiggindude6969's Avatar
Default Set up sheet for M&M Houston Initial run V2
Just wanted to share my initial set up sheet for the V2. For the first run 2 qualifiers, the car was dialed! I am going out again to play with the damper oil and the ride height, Most are running 4mm in the front and 4.5-5 in the rear.. Good times!
wiggindude6969 is offline
Old 07-06-2012, 06:45 AM
  #161
Default set up sheet.
File was too large...
Old 07-07-2012, 05:08 AM
  #162
We have to use rubber here in Australia, these are the combo's I've come across that should work for the F104 v2;
ALL Shimizu Racing tires for F104, but either Tamiya RIMS or TRG Rims.
The TRG rims are for foam, so you have to drill a hole and then glue them on.
You have to remove some ribbing from Tamiya RIMS to get these tires to fit as well.
Check out the F104 Pro thread on method for this mod to Tamiya RIMS (it's the first post):
http://www.rctech.net/forum/electric...ber-tires.html
FRONT
PS-0571
F104 racing slick tire front (soft)
RIM Choices;
Tamiya 51398 or 54201
TRG 5079 or 5080
FRONT
PS-0573
F104 racing slick tire front (medium)
RIM Choices;
TRG 5079 or 5080
FRONT
PS-0574
F104 racing slick tire front (F3 - Soft)
RIM Choices;
TRG 5079 or 5080
FRONT
PS-0577
F104 racing slick tire (F3)
RIM Choices;
TRG 5079 or 5080
REAR
PS-0575
F104 racing slick rear tire (R1)
RIM Choices;
TRG 5081 or 5082
REAR
PS-0578
F104 racing slick tire (R3)
RIM Choices;
TRG 5081 or 5082
Any others tried and tested for F104 v2?
Surfaces: Asphalt, concrete etc - no carpet.
Telinoz1975 is offline
Old 07-07-2012, 05:14 AM
  #163
Trader Rating: 19 (100%+)
Just purchased mine from RCMart. Everywhere else told me the car is out of stock before i checked out, but i think RCMart will take my money and then tell me "oh sorry, that item you just paid money for is out of stock... but here's store credit"... in any case ordered the car with the metal uprights, titanium screw kit, alloy motor mount and carbon wing mount, carbon damper mount plate, and pitch and roll spring sets.
Looking forward to running it over the next few months !!!
LordAnubis is offline
Old 07-07-2012, 05:26 AM
  #164
FRONT
PS-0571
RIM Choices;
TRG 5079 or 5080
FRONT
PS-0573
RIM Choices;
TRG 5079 or 5080
FRONT
PS-0574
RIM Choices;
TRG 5079 or 5080
FRONT
PS-0577
RIM Choices;
TRG 5079 or 5080
REAR
PS-0575
RIM Choices;
TRG 5081 or 5082
REAR
PS-0578
RIM Choices;
TRG 5081 or 5082
Rubber and foam is allowed in Victoria.
I only use ps-0571 front and ps-0575 rear if track temp is below 23-24 degrees. ps-0572 if above.
If track temperature is above 30 I switch to foams as I haven't found anything to work. Maybe rides will or tamiya rubber but haven't tried them since foams did the trick.
If RCMart says they have stock then they have stock. Probably one of the only shops that actually have accurate stock counts online.
J-PaP is offline
Old 07-07-2012, 06:10 AM
  #165
Ive had it previosuly where RCMart has told me something is in stock and it wasn't. I even bought something from their ebay store (a normal item... not something that was super and rare and jsut released) and was then told it's out of stock (which im pretty sure is illegal in ebay world).
In any case, i made a mistake this time. I forgot to change the standard delivery address on my rcmart account and my car will now be sent to my old workplace. Hopefully the emails i sent RCmart get to them and they can change the delivery address before it gets sent.
