New charger?
#34
well i have a 23 amp 13.8v power supply and i use it with my pulsar comp. 2 and i was woundering if i could use the ice with it too like both chargers at the same time. cause i aswell is looking for a new charger and i really like the aps dyno-charge one but i doubt i can use my power supply with it at the same time using the pulsar .
#41
Losi XXX S
i have a 25amp power supply from Radio shack
and i have charged two batteries at once (6amps) and used my motor checker to break in and test motors. it went off without a hitch. the motors were pulling 10-11amps on the checker.
some power supplies top out at a higher amp rating so if your breaking in a mod motor (that draws more amps) it should still be able to handle it since its only for a brief period of time.
#42
here the orion option
This charger is supposed to be avalible friday,
features::
•Charge 1 to 8 cells
•50 to 5400 mAh NiMH and NiCd batteries at 1 to 10 Amps
•11 to 15 volts D/C input
•Customizable Linear, Flex and Step charging
•5 charging memories
•Battery cycling
•Discharge at 1 or 10 amps
•Input and output short circuit protection
•Attachable battery charging tray
•Full motor run-in feature
•Powers commutator lathes
•Full manual lap counting functions and displays: time elapsed, average lap time and number of laps
•Indigo Blue backlight 2 x 16 characters display
•Customizable user name
•English, German, French and Japanese displays
•Easy to navigate, 4 push button settings
•Choice of 3 different alarm tones or silent function
•Silicone output wires
•Built in Clock
features::
•Battery cycling
•Built in Clock
#43
This dont apply for all chargers, the eagle/Integy for example, draws the same amps from the power supply, as it puts out for the cells.
#44
Originally posted by Mr. Shookie
OK let me explain about the APS Dyno-Charge .... Now for the charger porsion of the Dyno-charge.
1) The temp prob keeps it from false peeking
A temp-probe used in conjunction with delta peak cut off, only prevent over-heating. The peak cut off is still able to false peak
A temp-probe used alone CANT false peak (unless you use a ligther or similar to heat the probe up ). But using a temp-probe as the only cut off method is risky... forget mounting that probe, and the pack goes BOOM...
#45
Losi xXx S
I have a 25 amp power supply from radio shack, and it runs my pulsar, aps dyno charge and my millenium pro all charging at the same time, so you should be good for running you pulsar and whatever your new charger may be
