View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
I personally use these and highly recommend them too
https://teameamotorsports.com/collec...000mah-110c-2s
I need to update the rule, but most tracks have been following the ROAR voltage precedent, which is allowing the higher voltage batteries only charged to 8.4 V.
but how do the test the hv packs to get it to 6000mah. Is it at 4.22 per cell or 4.20 because that's a big gap and leave mah on the table
ROAR is 8.40 V, which is what most tracks are using. A 6000 mAh at 7.6 V nominal will be less than 6000 charged to 8.40 v. I'm not even going to try to make mAh equivalencies for 7.6v to 7.4v batteries, so go with the mAh rating on the label, period.
the quality of the pack means more than mah in all 17.5 or slower classes .
The only reason someone should be using a 6k pack is for weight in my opinion. Is that the best way to weigh the car down? No.. but when you have everything you can fit stacked in the center then that might be your only option.
So why even keep the 6000mah max battery capacity in the rules? As mentioned in previous posts the higher battery capacity(s) is only serving as ballast if you need it. Also it opens up the battery spectrum for racers who dont feel like spending $100 on HV lipo's. As long as you maintain the 8.4v rule, it all balances out
Another reason a 6000mah pack is used because higher capacity packs tend to be more expensive. (And yes, I understand high end 6000 mah packs can still cost a lot).
Who uses 10k packs in vta?
Need insight on cheating/ spirit of USVTA Rules
At my local club we have a member that's still using a Novak 25.5. I know for a fact he has realigned/ soldered his sensors on his board. There has been mention of him machining custom shims as well as other parts. His motor is stupid fast and recently this past weekend we had a very good driver install a 21.5 to test against this guys car. The 21.5 got waxed hard. I have been around the block for a while and raced at a few big events. I know what novak fast looks like and this is faster than Novak fast. With information above, would this be considered cheating? Rob and Myron I would like you to way in. An old novak should not be skull dragging a 21.5 let alone running USGT speeds on a big asphalt track. Most of us believe this guy is in the wrong. What's the USVTA ruling/ opinion on this? Thanks for any input.
