U.S. Vintage Trans-Am Racing Part 2 >
View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
Like Tree4318Likes
Old 05-09-2018, 01:49 PM
  #11746
rcguyfpr's Avatar
Trader Rating: 52 (100%+)
Originally Posted by belewis01
Don't know anything about the Tekin motor, but that gearing seems really low, most of our locals are about 3.3 or higher. Most current VTA motors are pretty close, the Reedy is popular here, with R1 and Team Scream starting to show up more often.
FYI, I'm running about 45 degrees timing on my Reedy, 3.3 FDR, Team Powers V3 speed control, SMC 6000 mah battery
Bruce, I m using Reedy with 2.9 FDR. Still 120F after the race.
rcguyfpr is offline
Old 05-09-2018, 01:53 PM
  #11747
eR1c's Avatar
Here is some recent results from my Reedy 25.5 ( VTA ) and Motiv 25.5 ( F1 ) motors - G Force Motor Analyzer
Interesting,
Now, have you tried both motors on the ground (not on an analyzer)? -do they confirm the test results. The reason I ask is that I've noticed that motors that had the highest RPM values on a motor analyzer were not necessarily the best performers when wheels hit the ground.
eR1c is offline
Old 05-09-2018, 01:56 PM
  #11748
eR1c's Avatar
WHAT??? 2.9 FDR!! ...no wonder my car seems slow ...my last race I was at 3.95 ...I think the last heat I swapped pinions and got it down to 3.65 ..but w/ serious cogging issues.
Lots of good stuff here to keep me busy w/ some tests on my motor. You all know what I'll be doing tomorrow! (I got the day off work). ...i'll post what I find out w/ my motor and getting my FDR to something more reasonable.
eR1c is offline
Old 05-09-2018, 02:00 PM
  #11749
rcguyfpr's Avatar
what chassis?
rcguyfpr is offline
  #11750
I'm not surprised - I need a little extra punch for when I screw up in the in-field
belewis01 is offline
Old 05-09-2018, 02:05 PM
  #11751
rcguyfpr's Avatar
But still not fast enough to catch the 1st guy. Need to find more grip from my PF tires.
rcguyfpr is offline
Old 05-09-2018, 02:06 PM
  #11752
eR1c's Avatar
what chassis?
I am running a 2014 Hobao H4e,
https://www.tqrcracing.com/shop/prod...YaAnIWEALw_wcB
I did quite well w/ it in our TC 17.5 class. Its a solid car, just not supported and have no idea what happened to the co', ..but they never continued improving it, etc. ...I have replaced it w/ a Schumacher Mi6 evo
eR1c is offline
Old 05-09-2018, 02:09 PM
  #11753
Interesting,
The Motiv is a different beast, I ran it one time in VTA and didn't get the timing / gearing figured out, so I put the Reedy back in since I knew that motor. Put the Motiv in my F1 and it hauls butt in the same configuration.
I think most 25.5 motors will work in VTA, but you need to find the timing / gearing sweet spot. I used to out run everyone on the straights, but got killed in the in-field, you have to find the best compromise.
Old 05-09-2018, 02:13 PM
  #11754
eR1c's Avatar
From everyone's comments I think your statement sums it all up best. Its a new class for me, so I think I just need to figure it out a bit more. Thanks for all the help, there is still hope for my Tekin! I plan to go back and really get my gearing correct as it obviously isn't right now.
eR1c is offline
Old 05-09-2018, 02:15 PM
  #11755
Bri
PS, just double checked, I'm at 48 degrees on my Reedy.
The Motiv looks to be the better motor. I would try it at 49 or 50 degrees timing but will most likely need different gearing than the Reedy since it's turning much more rpm. Get the gearing right on the Motiv and your car will be really fast.
Generally, what your looking for is when advancing the timing yields very small gains. When this happens, the motor is starting to lose it's efficiency and will start to run really hot. The Reedy data isn't as clear cut except the amp draw really jumps up with timing 50 and above. I would say 48 to 49 degrees timing is the sweet spot for the Reedy. Keep in mind that this is no load and will just get you in the ball park. I would use the data to find a good timing starting point and then go 1 degree each way and see what happens.
Best regards,
Brian
eR1c likes this.
Bri is offline
Old 05-09-2018, 02:26 PM
  #11756
eR1c's Avatar
...It looks like there is a serious RPM gain from 49 to 50 timing w/ the Reedy, -why wouldn't you go w/ 50 timing (instead of 48-49)? ...or am I missing something/not looking at it correctly?
eR1c is offline
Old 05-09-2018, 02:45 PM
  #11757
Amp draw.
What you don't know is what the torque and power curves look like for these motors. The big decision maker.
old_dude is offline
Old 05-09-2018, 02:52 PM
  #11758
eR1c's Avatar
..ah, missed that the amp draw.
yes, .. the torque and power curve is important. ....I've seen motors that put out insane RPM's on the analyzer only to not perform as well as those w/ RPM's much less.
eR1c is offline
Old 05-09-2018, 03:53 PM
  #11759
One thing you didn't mention was how big your track is. Low 3's are usually good for large tracks, but if it's a small (carpet?) track 3.9 might be better. IF everything is working properly, a sensored system should not cog. Some things to check (if you haven't already):
1-Try a different sensor cable.
2-Make sure your ESC is in sensored mode (if it has a setting for that)
3-Have someone check it with a motor analyzer. The Sky RC/G-Force one will usually give an error (or maybe just get stuck in an infinite loop) if the sensors are bad or a phase is gone.
4-Have someone else try your motor to see if it's an ESC problem.
You didn't say which ESC you were using, but I had a similar problem with a Reedy motor and a Tekin ESC. Swapped the ESC and was back to full speed. It may have been a settings issue in the ESC, but I haven't tried it since the swap.
Kevin Marcy is offline
Old 05-09-2018, 03:55 PM
  #11760
howardcano's Avatar
Trader Rating: 37 (100%+)
There is insufficient information to make that determination. Torque measurements are also required, just like Old Dude said.
howardcano is offline
