View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
3.5 FDR @ 47 deg
Location: 2.5 Miles South of Pentagon, Light years from reality
25.5
BATTMAN,
Thanks for FDR & timing info.
Rod
BATTMAN,
Rod
anyone have a setup for a TC7? for outdoor?
I just won the Scale Nationals with one. Seemed like it liked more timing (~50) and a smaller pinion.
Thanks for the info. I haven't touched the timing, it's at ~46/47 from the factor and I started with 3.62 (53/96) that I had on my Motiv and worked my way down one tooth per run today to end up at 3.92 (49/96) and the motor was still warmer than I like, but getting cooler, and lap times were improving. I couldn't go any lower on the pinion as 49 tooth was the smallest I had on me.
Should've asked. I had smaller pinions. Congrats on the podium.
I was too busy tryig to chase you down!
You got the podium because I was too slo-dium.
BTW, I really like that paint job you did on your Mustang. Looks sharp.
Troy set up my v2 Fantom at the Birds, This was on a larger carpet track, think it's at 48 deg, and FDR is around 3.5-3.6 with a 88 spur. although this was on a TC I think it would be applicable to a VTA.
24k trinity
Is the certified version legal or just the regular. It is listed as 1804 is legal but the certified is 1804X
Imo...no. Rob would need to officially answer that. But I've found some of the 1804x to have lower stator IR than what ROAR allows...and with 12.5 rotors. Plus it's given a part number on the ROAR list and 1804x isn't on there...just 1804. Also be aware that Trinity makes about 5 different 25.5 motors. So make sure you check before you buy if you are following usvta rules
Search - 25.5
http://www.teamtrinity.com/shop/index.php?route=product/search&search=25.5
