View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
U.S. Vintage Trans-Am Racing Part 2
#9361
A few years ago our race series allowed any 25.5 motor in VTA so I tired the SIMCO rotor. At that time I didn't have a way to measure the rotor strength but I did have a dyno and as I recall the SIMCO rotor, besides being more heat resistent it aloso had a slightly higher top end than with the stock rotor at the same timing (45 degrees).
#9362
Mark
#9363
Wasn't that SMCO rotor marketed several years ago as a RPM tuning rotor?
#9364
Yep - You would need to do as you say to make the claim as you state it; however, I said only that there was a difference in RPM. At the time, I was more interested in seeing if there was a way that my club could tech for a SMCO rotor without disassembling the motor for our 100% VTA legal races. As my posts back then indicate I was much more preoccupied with the 45 degree limit rule on the BOSS motor and the big differences between 45 degrees of end bell timing and how much timing was being actually being measured (Motorlyzers G-Force etc.).
We just have to be careful with 'conclusions' posted here on RCTech, because the next thing you know it'll be a 'fact' at tracks all over that a SmCo rotor gives more top end.
#9365
#9367
Fair enough. Around here the 25.5 TC class with the Novak motor is getting popular. With the high motor temps in this class (as well as VTA these days), perhaps we should be looking at the SmCo rotors more from of an endurance perspective (i.e., resistenace to heat) than performance, which in my case at least wasn't much at 45 degrees timing.
#9368
Yep it is gone...RIP...you can set the timing at anything you want. Just be careful in using the endbell timing sticker to set your timing because of, as a fellow racer noted, the random nature in which the timing sticker is attached. For example, my first BOSS motor at 45 degrees timing on the endbell sticker was more like 68 degrees on my Motorlyzer. Others that I tested were less than 45 degrees. Today with no timing limit, it is easy to see why some BOSS VTA motors at 45 degrees endbell timing were awesome and some were better used as paper weights. At least now the playing field is more level for everyone.
#9369
All this timing talk gives me a headache. It really means very little. There is ZERO reason to crank it to the moon and get high motor temps. I run mine around what on the can is between 35 and 40 degrees. My car accelerates faster than any other at our track and has equal top speed. I'm geared at 3.44 FDR and the motor could run without a fan if I wanted to. With a fan it comes off track around 100/110 temp.
If you are constantly running your motor hot enough that the neo magnet rotor can't handle the heat, you are loosing tons of power through heat in the armature.
The pros do it because they have one run or one race day motors. Burning one up, as long as it doesn't happen during the race means nothing. I bought a motor from company x. Asked then directly what is the suggested timing and gearing for the conditions I had. I went with it. The car was quick, but motor was around 180 with a fan. If had lost the fan, the motor would have smoked. I lowered the timing from 49 to around 35, and geared up a tooth or two. No real noticeable difference in overall power, but motor hovers around 120 with a fan. Now I don't worry about losing the fan. Motor will get hot without it, but I won't lose it.
You have the find the best timimg/gear combo for YOUR motor. It takes time and work to get to this point.
This part is to read on the voice of Yoda.
Excess timing is the path to a slow car
Timing leads to temps
Temps lead to resistance
Resistance leads to weak motor.
#9370
#9373
Trader Rating: 32 (100%+)
#9375
The new rules will go into effect when we start the next National Championship Point Series.
