U.S. Vintage Trans-Am Racing Part 2 >
View Poll Results: what's your tire choice?
Protoform
46
30.67%
HPI
104
69.33%
Voters: 150. You may not vote on this poll
Like Tree4318Likes
Old 10-19-2012, 03:12 PM
  #2221
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Originally Posted by DARKSIDE
I use the AE TC6 gear diff in my TC5...with no mods...no cutting or shimming...not sure why it doesnt fit...or maybe more Chuck Norris juice...but I pullrd my ball diff out and put the gear diff in...simply
also TC5/6/6.1 shocks will fit TC3/4...this is what Im upgrading my TC4 Club with...
Part #: 31344
RC10TC6 Gear Diff
Part #: 31323
VCS3 Shock Kit
WTF now I wish I never sold my tc5 Myron thanks your the best
rcpaintinpete is offline
Old 10-20-2012, 06:28 AM
  #2222
hyperdrive1's Avatar
Default gear diff
Hey guys...question.
I am fairly new to VTA racing and I have a TC6 with many 6.1 parts on it. I have the car working pretty well on carpet, but from what I have read maybe I need something heavier for lube in my front gear diff.
I have gear diffs front and back...back spins fairly free and front is a tad bit stiffer but not siff by any means...so my question is where is a good place to start with lube thickness and where is a good place to get it from (in the US)
hyperdrive1 is offline
Old 10-20-2012, 07:00 AM
  #2223
shadowracer24's Avatar
Hey Benny, start with 100,000 up to 500,000 in the front for our track. Just switched to a spool in mine and like it better. Give me a call and I can help ya out more.
shadowracer24 is offline
Old 10-20-2012, 07:02 AM
  #2224
Suspended
BA BA BA benny lol
im using 300,000 in the front and 2000 rear on carpet
you can try www.superiorhobbies.com
Old 10-20-2012, 08:06 AM
  #2225
DARKSIDE's Avatar
spool best for TC6/6.1....
DARKSIDE is offline
Old 10-22-2012, 01:23 PM
  #2226
DARKSIDE's Avatar
Default AE TC4 Club Racer for USVTA
well Im hooked on the TC4 Club Racer for VTA...this car/chassis is great for the class...
for 2 weekends Ive run the car and its great...1st weekend with it I turned a fast lap of 12.6, this weekend dropped to 12.3's, which is on par with low 12's from the Nats(12.1's fastest)
1st weekend it was straight out the box with no setup and it was good...
this is what I did this weekend
5mm ride height f/r
7 droop front
6 droop rear
35wt(AE) front
30wt(AE) rear
-1.5 camber f/r
removed 8 metal srews in the bottom of the chassis and put in FT blue aluminum screws
ele...
Hobbywing Justock esc...open box settings...
Novak SS 25.5 reman, ring on motor at full motor timming
Robinson 78 spur/Trinity 54 pinion FDR 3.61
AE fan duct system
XP servo
car weighs in at 1553 without driver figure(Im out) running HPI 69 Chevy Z28 Camaro w/ shoo goo front and rear
New Tires all around and 2mm washers on front( I do have a little rub on the body)
no parts were broken or damaged....
This chassis is perfect...Ive always like my TC3, but this car works well and straight out the box
DARKSIDE is offline
Old 10-22-2012, 01:26 PM
  #2227
Meradin's Avatar
Trader Rating: 19 (100%+)
How do you adjust the timing on the SS?
Meradin is offline
Old 10-22-2012, 01:27 PM
  #2228
DARKSIDE's Avatar
Ill be adding TC6 shocks and sway bars next, as well as a new lipo...
If VTA is something you want to try...this is it...
DARKSIDE is offline
Old 10-22-2012, 01:29 PM
  #2229
DARKSIDE's Avatar
3 screws on the endbell, loosen them and turn the black ring..and then tighten back...BUT DONT OVERTIGHTEN
DARKSIDE is offline
Old 10-22-2012, 02:53 PM
  #2230
AdrianM's Avatar
Any trick to breaking in new tires so their grip comes up faster?
AdrianM is offline
Old 10-22-2012, 03:14 PM
  #2231
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
What lipo you changing to?
Flying Monkey is offline
Old 10-22-2012, 04:06 PM
  #2232
I actually put mine on my tire cutter and run a file across the surface at slow speed just to knock the glaze off the tire. But runnin it up and down the road in front of your house for one battery will do the same thing. They usually start workin pretty good after about two runs at the track then.
Old 10-22-2012, 04:16 PM
  #2233
alloyslash's Avatar
My last set I took a flat file and lightly drug it over the tread til the glaze was gone, just kinda " scuffed " them in. Then I took SXT 3.0, coated them, took a rag and massaged them off a few times. After that I coated them and put em in a ziploc over night. It seemed to me that it helped.
alloyslash is offline
Old 10-22-2012, 04:36 PM
  #2234
DARKSIDE's Avatar
I have different ways, depending on the event...
for regular club races...natural wear is best...
I normally mount the foams,tires, and rims and let them sit for a day or 2
then I put them on the car and blip the throttle a couple of times to make sure its seated well...then I glue them up...
dope the tires alot to get them broke in...
for special events wear tire thread is a must...ha ha...thats a good one...
DARKSIDE is offline
Old 10-22-2012, 05:03 PM
  #2235
DARKSIDE's Avatar
staying with the best lipo for VTA...Reedy 5000 25C Wolfpack...just need one for this chassis...Im using same lipo for 2 classes...lol...ran 3 classes Sunday, with one charger LRP Pulsar Touch, and 2 lipos...Wolfpack and Reedy 6500 65C
I tried all of these years ago...and the performace was never better than natural wear...
dope the tire with sauce and run it...tire warmers help as well..this will give you the longest wear and use of the tires...imo
Now for big events that require tread across and break in is not possible...here is my trick
new set of tires and open the package
remove the foams and put the tires in the bag
add Reino's Magic Marinade to the tires in the package
fold the top of the package and seal it(staples)
massage the tires and sauce in real good
put them out in the sun for a 1 hour or 2( but make sure you watch them, you dont want them to swell)
then remove the tires from the bag and clean with Reino's cleaner
let them completely dry
finally let them sit like I do for reg club mount
extra soft and very ready to turn fast laps off the start
draw back...tires wear really fast
DARKSIDE is offline
