Old 02-13-2012, 01:05 PM   #31
EskimoGangsta's Avatar
Send a message via AIM to EskimoGangsta Send a message via MSN to EskimoGangsta Send a message via Skype™ to EskimoGangsta
Originally Posted by racing_jason View Post
i would deffinately try gearing down that seems really high and maybe a slight less amount of turbo. also double check that you have your endbell timing at 0. those should help you with the brakes. i have ran this software now for a while and i have had very good success with the brakes. only other thing that it could be is a bad cap make sure the cap is good as well.
thanks Jason
I never run any endbell timing. i like the feel of gearing up a tooth then raising the endbell timing. and just from experience i find raising the timing to get the same amount as top speed with gearing creates more heat. Even with my gearing i've never blown up any motors while racing.
Live, Laugh, RC
EskimoGangsta is offline   Reply With Quote
Old 02-13-2012, 01:08 PM   #32
Originally Posted by Randy_Pike View Post
While your motor temps are fine this setup is over doing the track especially with the gearing. Try turbo delay .15, 10 turbo boost, 2.0 ramp rate,45-50 on boost.
You still didn't tell me where the motors mechanical timing is set?
I have tried my car with a 34 tooth pinion when i was running 212 and i didn't like how snappy it got on me, i drove more consistent and smoother with the 36. and my mechanical timing has always been set to 0deg.
Live, Laugh, RC
Old 02-13-2012, 01:31 PM   #33
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
Right but if you're over geared you're not giving the motor any leverage to slow the car down.
It's like compression braking in a car. You must downshift to use it.
If you prefer the 212 braking by all means, go back to it. That's why we left both versions intact.
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 02-13-2012, 01:32 PM   #34
racing_jason's Avatar
if it is getting snappy on you i would recomend lest boost say about 45 or so and that should smooth it out and being able to gear down. and then maybe also lengethn out your delay as well.
Thank you to my sponsors-
Team Associated-Reedy-ProLine-B&B Hobbies Racing
racing_jason is offline   Reply With Quote
Old 02-13-2012, 06:27 PM   #35
Ya, I'll give less boost with less gear a try. thanks
Live, Laugh, RC
Old 02-14-2012, 06:45 PM   #36
Team Tekin
Randy_Pike's Avatar
We have had requests for additional brake power in boosted spec TC classes, and we are going to give it to you. We are adding a new active brake setting that will feel more like V212 in super boosted setups at high rpms. So for those of you that feel that the 222 brakes are a bit weak at the end of the straight away this will give you the additional power you're looking for. In classes like 2wd offroad 212 brakes had room for improvement in feel and modulation. Now that spec racing is becoming more popular the team felt that the added driveability of the 222 brakes made for faster laptimes, something we're always looking to improve.
Old 02-14-2012, 08:23 PM   #37
Groomie's Avatar
When will the release be available ???
WSRC open and ready to race
Check us out at
http://www.facebook.com/WesternSydneyRaceCentre
Groomie is offline   Reply With Quote
Old 02-14-2012, 10:09 PM   #38
And this is why i go Tekin!
Thumbs up guys
Live, Laugh, RC
Old 02-22-2012, 08:49 PM   #39
Kent Beal's Avatar
Trader Rating: 65 (100%+)
What's the update on the V222 software, it's off the Tekin website???
Looked up the word "ninja" in the dictionary yesterday, it said " ninja not found", well played ninjas, well played.
Kent Beal is offline   Reply With Quote
Old 02-22-2012, 08:55 PM   #40
Odin544's Avatar
Trader Rating: 93 (100%+)
when its ready it will be released as V223.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Tags
brakes, rs pro, tekin
