Exotek F1R
#1081
#1082
Its summer! where do I buy this IFS for my F1r2?
#1083
What is the advantage of a trailing axle setup?
#1085
Hey guys. It took me a while to get to this point because I started reading the thread back from the beginning. I wanted to understand how the chassis progressed.
I keep seeing mention of the "Tamiya red spring that looks more orange". Would this be it.........http://www.tqrcracing.com/shop/produ....asp?p_id=1506
Zo
Zo
#1086
Zo
Zo
We have all the metal parts in the warehouse. Still waiting for the molded parts to come in from the factory
#1088
Mike,
Thanks for the quick response. And thanks for a quality conversion kit. I've purchased the F1R2 pro conversion and adjustable front arm set. Everything is top notch! With a donor F104, I'm pretty close to being set. I'm really interested in the IFS when it hits. I've got some questions about some parts, but will send those to the support email.
P.S. I plan to attend 2015 Snowbirds, so there will be at least one Exotek there.
Zo
Zo
#1090
OK, I know that I'm a lazy bonehead, so we'll enter this discussion with that as a given.
I am trying to finish my F1R2 and had my Exotek spur arrive yesterday. I am using a Tamiya diff hub, etc on a Yeah Racing spring steel axle. I put a bearing in the gear. I put a bearing in the spur gear side of the hub. When I tightened it, everything bound and I had no diff action. Took it apart and tried again. Same. Pulled the bearing out of the spur gear side of the diff hub ("Hey! That spur gear has a shoulder on it! Maybe that is causing the problem?") and everything SEEMS to work fine. I am not confident that this is correct. Am I lucky, or still a bonehead?
Scott
Scott
#1091
Scott
Scott
#1092
Hi Mike,
Will the IFS be legal to run at IIC? (if it is out by then)
Any idea on the price?
Thanks,
Nick
Thanks,
Nick
#1093
I think you would be ok with a conversion F1 chassis. It is mainly all locals and practice is free. I think they mainly just want to stay away from mod x-ray sedans and that type of crowd. Saturdays at Tamiya are more for fun and relaxing. And hey Im sure its got Tamiya parts on it anyways! lol
This is typically my base setup at Tamiya
I find that starting with fresh rubber is best there. So newer tires would make your day a lot more enjoyable!
Front:
3.5mm hide height
8.5 degrees caster
Associated 0.016 front springs (normally my go to spring)
-1.5 degrees camber
2 degrees toe out
Standard Tamiya In-line front axle
2mm bump steer (the steering links should be slightly pointing down toward the center of the car at hide height “\ servo /”)
Main Shock:
3-hole piston
25 weight (Associated oil)
Tamiya fluorescent Red Spring (looks like orange though)
1mm droop (thread lock the spring retainer onto the shock shaft)
raise the rear female ball stud 6mm for better shock movement
Side Suspension:
Associated kit silver spring
10 oil in dampers
No washers under any of the side links
Rear Pod:
Long Wheelbase
31/88 gearing (64 pitch)
Associated Diff lube on diff balls
4.0 mm ride height
Tires:
pit 72 rear with tamiya kit medium tire. (belt removed with stock foam)
I sauce the tires with buggy grip
Cleaned with Tuning Haus Tire Cleaner/ Conditioner
Other:
Asphalt I run no weight on the winglet. It is actually a pretty huge change in how the car drives
Reedy Sonic 2 Motor
Reedy short pack mounted forward
LRP SXX V2 mounted in the back with optional 3-barrel capacitor
X-ray servo saver
Tamiya F2012 Step nose body, rear wing, and front nose piece. I run the McLaren front wing (The holes line up between nose-piece and wing)
Front:
3.5mm hide height
8.5 degrees caster
-1.5 degrees camber
2 degrees toe out
Main Shock:
3-hole piston
Side Suspension:
10 oil in dampers
Rear Pod:
Long Wheelbase
4.0 mm ride height
Tires:
Other:
Reedy Sonic 2 Motor
X-ray servo saver
#1094
Price is something that needs to be worked out along with a release date.
Mike,
Zo
Zo
#1095
Hi guys,
just bought an f1r2 on the forum and this will be my first formula car.
Got a few questions though:
1. any weak points/ parts I need to get as spares
2. Which height adjusters fit? I got a tonload of 1/12th ones but will these work in the rear?
3. front springs the same, do 1/12th or pro10 front springs fit?
For the rest I hope, just another pancar ;-)
