Exotek F1R
#2491
Yes I would like to know also I want to get the F1r3 with the Ifs to and all needed parts to build it for my nex f1 thanks
#2494
What happened to the IFS are you no longer selling it ? Don’t see it on the Exotek website
#2496
Just ordered a F1R3.I run on a large asphalt track what will the chassis rails part #1571 do.or is that for carpet tracks I have the IFS also track is outdoors thanks
#2497
I guess nobody knows or it’s a secret ? LOL
#2498
As far as the IFS, I couldn't make it work to my liking. It was fast but not comfortable to drive at the limit (nervous and squirrely). I put a conventional front end back on it and the car was fast AND easy to drive at the limit.
Hope that helps.
Mark C.
#2499
Yes. I run the R3 with IFS and also the duel crank steering kit.
It works very well but needs setting up a little different to the "normal" front end.
You can run the rails on asphalt also.
With IFS but no rails I would try gun metal front springs (reasonably hard) and very soft side springs (Black Assoc') with 10K damping oil.
If you want to go with the rails, you can come softer on the front springs.
Set your diff' as light/ soft as it will go. If you oversteer at corner entry, off-power. Then slowly stiffen the diff' a little at a time until the oversteer goes away After that, tune to your liking.
Hope that helps you out.
Regards
BM
#2500
Ok.thanks guys.I will try the IFS. I got one used because Exotek does not have them anymore on the website. I don’t have the crank steering set
#2501
Thinking of getting the F1r3 steering set #1668 part for my R3.what do you guys think of it. I run on a large asphalt track in Florida I don’t race all that much and I don’t push my cars that hard I just enjoy the hobby.the steering set looks nice but is it worth the money to get? And what will it really do for me and the car I am not a pro driver I do ok is all.thanks Jerry
#2502
@5th, if you enjoy the hobby you will enjoy installing the steering set, its great, even for bench racing!
I quit the rc-hobby, so my R3 is for sale: Exotek F1R3, IFS, Alu, KoPropo, Mylaps, Hobbywing complete as new
#2503
#2504
May I your kind input on how to measure the caster with these Exotek suspension arms? Much thanks!
#2505
