Exotek F1R
#2146
The F1R3 continues to run great. We had the Full Throttle race on August 13-14 on our new CRC black carpet. The car worked flawlessly but driver was a little late figuring out 25.5 correct gearing and running the wrong front tire. However, by the last A-Main I was able to set the fastest lap and fastest run of the day. Eventually I finished up 2nd but the car was the best one on the track by the end of the day
http://www.redrc.net/2016/08/2016-fu...nships-report/
idbdoug
idbdoug
#2151
What parts are needed to turn my TRF101 front into IFS?
#2152
I don't believe the Exotek IFS will work with the TRF101, not 100% sure though, I think you must have an F104/F103. But you also have to have the Exotek F1R3 or R2 conversion, as the stock F104 chassis is too narrow for the droop screws. You must also use the Exotek adjustable upper arm set for the IFS setup, as well as the Exotek F104 servo mount.
Hope this helps!
Hope this helps!
#2156
Last edited by Serzoni; 08-25-2016 at 01:23 PM. Reason: Added image of droop screws
#2158
Cool, thanks for the clarification guys. I need to do this on both my TRF101 & 102.
Got the HPI mirco Exotek chassis and the Exotek Exo6 for my TB Evo6, and they are both HIGH quality upgrades!
Again, thanks for clearing that up - I thought you had to do the F1R3 chassis conversion to get the IFS to work. . . Nice to know - should've asked.
#2159
Thank you
#2160
Dose the F1 15 Protoform body fit on the F1R3 chassis? I'm making the switch over to carpet for the winter and I was wondering what body and wings will work.
I'm currently running the F1R2 chassis outside on asphalt with a slim 3000mah lipo. I know switching over to transverse battery layout and aluminum chassis for carpet will be the hot ticket. Thanks!
