Like Tree209Likes
Exotek F1R
Old 01-18-2016, 04:09 PM
  #1816
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by razor41
A few setup weapons to combat grip roll..
  • Battery transverse mounted
  • Widen the front and rear axel to maximum within rules (190mm?)
  • Softer side springs
  • Softer side damper oil
  • Softer front springs
  • Softer shock oil
Basically you want the car to roll on the suspension. Going harder on everything may be your initial thinking but it will make things worse. When grip is very high, the car will behave better when it leans and pitches. When it hits the limit of lean it will then grip roll but you will have more time to react to that. A harder setup will have reduced lean and the car will flip suddenly with sharp steering input.
Hope this makes sense and helps!
Well said!
Originally Posted by wheelz
Hey Guys,
Just want to let you all know that I won the third round of the Tuning Haus Scale series with my F1R3 and have updated the setups sheet with what I ran yesterday and also some pictures of my car and heat sheet.
I am still trying some things out and there may be another revision or two in the coming weeks.
Hope all is well and you're enjoying the cars
Aaron
Great job Aaron!
I can't wait for my 2016 season to start
MikeR is offline
Old 01-18-2016, 06:38 PM
  #1817
wheelz's Avatar
Originally Posted by idbdoug
Can you explain axle height adjustment as a tuning option? lower, middle, and higher axle height has what effect??
thanks
idbdoug
sure
note: after every change to the front spindle spacing you WILL have to recheck the front droop and ride height! Also 1mm of change can be a huge difference on carpet
-Lowering the spindle (putting shims on the top of the spindle) puts more weight to the back of the car during a suspension cycle and will make the car steer less and will result in a more stable front end. typically I will do this for asphalt to make the car not oversteer.
-Raising the spindle (putting shims on the bottom of the spindle) puts more weight on the front end of the car during suspension cycles/body roll and will give the car more steering. mostly steering out of the apex.
-Adding shims to the top of the spindle only (ie not changing the overall spindle height) will increase the camber gain during cornering. This can give the car more steering in 180's or where the car is leaning over the most. adding camber gain will keep the main tire patch on the ground instead of the tire rolling over onto the sidewall.
I hope this helps. It's something to definitely play with as it only takes a small change to make a huge difference on track...
Aaron
wheelz is offline
Old 01-18-2016, 08:12 PM
  #1818
idbdoug's Avatar
Trader Rating: 41 (100%+)
sure
Aaron
Good stuff, thanks
idbdoug
idbdoug is offline
Old 01-19-2016, 12:10 AM
  #1819
Matthijs's Avatar
thanks Aaron and Mike! The alu chassis is a very nice option. For the first time I didn't have to worry about traction rolling the car into the boarding at the end of our straight (tight carpet track), instead it would oversteer and I would loose the rear ;-)
Matthijs is offline
Old 01-19-2016, 05:09 AM
  #1820
idbdoug's Avatar
Can you still use the older F60, MP4, and F104 kit bodies with newer F1R3 car?
idbdoug
idbdoug is offline
Old 01-19-2016, 05:26 AM
  #1821
British Menace's Avatar
Hi Matthijs....
I was just reading your post above. Just curious. When your car was "over steering" with the new Alu' chassis, did you have the battery placed inline or traverse, or do you happen to know what weight distribution front to rear your car had/has?
Thanks.
Regards
BM
British Menace is offline
Old 01-19-2016, 06:05 AM
  #1822
Matthijs's Avatar
idbdoug
not the f60 and mp4, they are too small (didn't test it, but read it in this thread). Don't know about the 'older' f104 body.
Originally Posted by British Menace
Hi Matthijs....
Thanks.
Regards
BM
battery placed traverse, soft springs all around and no preload on the side springs. It is a good thing actually, with my other f1 cars if I go too fast into the 90 degr left turn after the straigh it would tractionroll into the boarding or understeer into the boarding, the alu chassis saves me parts
Matthijs is offline
Old 01-20-2016, 09:14 AM
  #1823
scirocco14's Avatar
I know everyone is moving on to the F1R3, but don't discount the F1R2 just yet! I got this F1R2 in a trade from a local racer who was frustrated and wanted to move on to something else. It has the IFS on it as well.
It took me three race weekends to get it sorted out, with some great help from Aaron. I had been racing my F1R successfully, usually somewhere on the podium. This weekend's race there were 9 F1s, with an assortment of Xrays, Tamiyas, Exoteks, and one Fenix Su.zuka.
TQ and 1st in F1!
Thank you, Aaron for all the help! The IFS really changes how the car feels and I'm still learning how to tune it.
Mark
Attached Thumbnails Exotek F1R-12615242_1040531285986022_3481463607437788546_o.jpg   Exotek F1R-img_8536.jpg
scirocco14 is offline
Old 01-20-2016, 11:40 AM
  #1824
Trader Rating: 30 (100%+)
I too want to give a big shout out to Aaron. He has been nothing but a great help to me. He's not too shabby of a driver either
littleZEN is offline
Old 01-21-2016, 10:21 AM
  #1825
F1R3 ready for the Snowbirds next week.
Serzoni is offline
Old 01-21-2016, 10:40 AM
  #1826
MikeR's Avatar
Classic Renault-LOVE IT! Good luck at birds!
MikeR is offline
Old 01-22-2016, 10:12 AM
  #1827
Matthijs's Avatar
for the IFS, where can I find some damper tube ball ends? the 10mm version? I've got the 12mm from 3racing/kyosho but would be nice to have the originals (wich I messed up ;-) )
Matthijs is offline
Old 01-22-2016, 12:04 PM
  #1828
MikeR's Avatar
12mm is original short style;
http://www.tqrcracing.com/shop/produ....asp?p_id=1944
15mm is the long style.
MikeR is offline
Old 01-22-2016, 01:07 PM
  #1829
Trader Rating: 32 (100%+)
Very cool. Where did you get the decal sheet from?
racenut123 is offline
Old 01-22-2016, 01:16 PM
  #1830
It's the F1 Paint Lab sheet. (Although the FW16 was 1994, not 1995 )
http://www.tqrcracing.com/shop/produ....asp?p_id=7087
Serzoni is offline
