Team Much-More cell master v1 >
Old 06-08-2005, 09:40 PM
  #466
litespeed-dom's Avatar
Originally Posted by DirtyDog3375
Just another question, how does everyone keep the temperature probe on their batteries? I am using tape at the moment and it is rather annoying. Any ideas or alternatives???
Tape??? I just stick in right down the middle of the pack.
Dom
litespeed-dom is offline
Old 06-08-2005, 10:09 PM
  #467
danjoy25's Avatar
Trader Rating: 38 (100%+)
I saw the much more racing battery warmers and they have a hole in the middle for you to insert the temp probe.
danjoy25 is offline
Old 06-08-2005, 10:31 PM
  #468
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
thanks for the quick replies fellas. I will try your suggestions.
DirtyDog3375 is offline
Old 06-08-2005, 10:40 PM
  #469
Entropy's Avatar
I usually just stick the temp probe in the gap between the batt bars and the ends of the cell, its snug wont fall out unless u accidentally snag the temp prob wire. Since the batt bars draw the heat out from the core of the cells its fairly accurate.
Entropy is offline
Old 06-08-2005, 11:45 PM
  #470
Ryan Lee's Avatar
Default Tips for Temp. probe
I put 2 rubber O-ring to Big screw of Battery heat sink. they hold temperature probe well.
Ryan Lee is offline
Old 06-09-2005, 10:03 AM
  #471
What's happened. When the Cell master connected to the power supply.
G2B Anthony is offline
Old 06-09-2005, 12:37 PM
  #472
Guo Chean's Avatar
i think you need to reset your cell master factory setting first. if cannot work just send to the distributor they will help you solve it.
Guo Chean is offline
Old 06-09-2005, 03:06 PM
  #473
Arun's Avatar
Originally Posted by litespeed-dom
Thanks Keith!
Now, is anyone using the MR fan with their charger? If so, do you guys set it to go on during certain temp on charge, and/or discharge? Now, the debate has always been let the cells cool off naturally, so how would the fan enhance charging or discharging?
Dom
I have tried both the battery heat sink and fan stand in the heat. Though the fan stand keeps the batteries cooler (especially when running high delta peak dropoff values on the CM), the battery feels more "alive" when I use the battery heat sink .
I rarely get a "temp cut" when I use the 48 deg setting in combination with the fan stand. I use the fan stand mostly for cooling down motors and batteries after a run, and then I point it in my direction when not in use .
Arun is offline
Old 06-09-2005, 09:57 PM
  #474
Thank you for your help ^.^
But I dont know how to reset the cell master , it is holding such as my attach photo as above when I connected to the power supply, any one have this problem? It seem very easy to get error . I bought it just 2months and used under 10 times. so sad.
Old 06-10-2005, 12:04 AM
  #475
Default Reset
Instructions for reset are on page 4 of the user manual - you can download here:
user manual download
If you still have problems, just return it to the shop you bought it from for service.
Thank you,
Keith.
keithander is offline
Old 06-11-2005, 03:05 AM
  #476
Joep's Avatar
Default Cooling AFTER charching
Why is the fan not controlled by temperature after charging?
Cells tend to increase their temp. after delta peak cut off.
Or am I missing a setting?
Joep is offline
Old 06-11-2005, 06:44 PM
  #477
Trader Rating: 90 (100%+)
Originally Posted by kumpol
___________________________________
Steps 1st
current 7.0 A
capacity 2650 mAh
Flex off
Steps 2nd
current 0.2 A
capacity 2680 mAh
Flex off
Steps 3rd
current 4.0 A
capacity 4100 mAh
Flex off
delta V 06mV (6cell)
Temp 48
repeak 1 delay 5min. repeak capacity 250mAh
Surikarn gave me this profile to try on GP3600 and Int3700, so I assume this profile is ok for them. I have not used this profile yet so let me know how you like it.
Kumpol,
I need some clarification. I see a lot of people talking about delta v setting of 3mv per cell or 6mv for 6 cell. 3mv per cell would equate to 18mv. Correct? Or do I look at the delta v like the cut off on a GFX (.03 as a pack).... But on a Novak Millennium your mv threshold might be set @ 48mv................................ I have been using a step charge and a straight linear charge, but I am a little concerned about the drop back settings....
Any help or clarification that you can provide would be great...
RBLove is offline
Old 06-11-2005, 07:44 PM
  #478
Regional Moderator
kumpol's Avatar
06 on the CellMaster = 6mV(0.006V)/pack
It looks like a high number per pack but you will not get overcharged 'coz the peak cuts at 48 degree C (118 Fahrenheit).
kumpol is offline
Old 06-11-2005, 08:02 PM
  #479
Regional Moderator
kumpol's Avatar
Step 1
2600mA 7.0A
Fn
Step 2
2630 0.2A
Fn
Step 3 4200mA 5.0A
Tn 48 10 R1
This profile is from Ryan Lee. He set this for a couple people in 19T class at the Reedy 2005. And I found out this was very good for 19T class at the Reedy.
kumpol is offline
Old 06-11-2005, 09:54 PM
  #480
Regional Moderator
kumpol's Avatar
Ryan Lee won in B Main - Open Mod at the 2005 Reedy.
DC Motor Sports Powered....baby!!!
kumpol is offline
