Like Tree1Likes
GT8 Lite
Old 09-06-2011, 06:45 PM
  #106
Rkk
Rkk's Avatar
Originally Posted by FangsCPO View Post
I added about 6mm tubing to my rear shocks and it's running alot better. I may try the front but I don't want to compromise my steering.
I was able to get the front low enough without the tubing.
Rkk is offline
Old 09-08-2011, 09:52 AM
  #107
FangsCPO's Avatar
I actually used about 3mm tubing in the front shocks and did some other tweeks. I think it's doing a little better. I really like how with the tubing in the shocks it doesn't look like it's going to tilt over when turning anymore. LOL!!!
It's all trial and error.
FangsCPO is offline
Old 09-09-2011, 08:48 PM
  #108
CrazyRonny's Avatar
I did the STRC conversion on my slash 4x4 and I try to fit the Protoform PF8 body on it... and it look like the body is about 10mm to wide on each side... I saw some use this body and it look to fit ok
I used Ofna "OFN86026 - WHEELS, V-SPOKE WHITE 1/8" and "OFN86052 - OFNA 1/8 Buggy Tires, GTS Treaded (2)"
Is there a body out there that fit better?
CrazyRonny is offline
Old 09-09-2011, 08:57 PM
  #109
FangsCPO's Avatar
I'm using the same one you are and yes, I also wish there was a more narrow lid for this conversion. I looked high and low and found nothing. Most GT8 lids that I came across were 12 or 12.5 inches wide. I did fine one lid that was narrow but it was too narrow. It was 10 inches wide, it's made by Thunder something.
What hurt me is that I'm using Tekno M6 Driveshafts so I'm stuck with those adapters. If you use the stock drive shafts, someone out there makes adapters that have 2, 4, and 6mm off sets. That would help the lid look better. For now, I'm happy with what I have and it works for me. if you find something, post. Thanks!
FangsCPO is offline
Old 09-12-2011, 11:34 AM
  #110
Originally Posted by SNR Graphite View Post
My chassis is not that much longer I am still using stock universal front and rear. I think it because my chassis is flat which make it a little longer.
I have to safe some money first, then I'll order your carbon chassis..
fx35rc is offline
Old 09-28-2011, 01:48 PM
  #111
FangsCPO's Avatar
I'm still looking and have not found anything.
FangsCPO is offline
Old 10-01-2011, 03:12 AM
  #112
bobbyblaze's Avatar
have anyone try the conversion kit on a 2wd slash, reason i'm asking i have 2wd slash that haven't been driven in 2 years..just wanna know ifany cons & advice?
bobbyblaze is offline
Old 10-17-2011, 01:16 AM
  #113
kcunamay's Avatar
Trader Rating: 20 (100%+)
I'll be running with you guys in corona next time out. Just need to finish mounting the race gear.
kcunamay is offline
Old 11-19-2011, 01:23 PM
  #114
Originally Posted by RC Passion View Post
Here's Nestor's Nastruck lite (Jammin SCRT home brew conversion) 1st debuted @ DHW!
We'll see if i can get him out to race @ Corona Hobby Town August 21st!
What body is this and where can i get it
WishUCould00 is offline
Old 01-13-2012, 05:31 PM
  #115
That is a Proline Desert Rat body. Just leave the extra lexan on the fron and trim the rest accordingly.
jstrime is offline
Old 01-14-2012, 06:12 PM
  #116
I don't have any pictures just yet, But I'm currently almost finished wiht my GT8 lite conversion. It's based off a slash with an SSC LCG chassis. Extremely light and low profile, it was actually running oval with a 9t 1.10 touring car and doing well in the straights. I was very impressed. Picks will be forthcoming
one question- are the ofna tires/wheel good enough to get started with?
txaggie08 is offline
Old 01-15-2012, 09:00 AM
  #117
I'm doing a build with the SSCLCG chassis too. I'm running the Castle 2650 Monster 1/8 scale motor with the ofna rims and tires that come stock with the dirt oval kit.
I can't wait to get it together and tear up the track !!!!
jstrime is offline
Old 01-15-2012, 03:50 PM
  #118
I couldn't believe it was running on par with a 9t motor in that tc5.... it handles VERY well btw, if you can control the body roll issues. I'm still working on that... I'm thinking stiffening things up may help.
I know a lot of you don't like to share setup tips etc..... but would yall recommend going back to a slipper in the center? What about locking the front diff?
Old 01-16-2012, 02:40 PM
  #119
I would run front shock towers in the front and the rear. Run the Revo shocks all the way around. I'm going to see if the revo spool will fit in the front to lock the front up. Most people run a slipper, but tighten it all the way down to act like a spool too.
This is going to be so much fun !!!! I just can't wait.
jstrime is offline
Old 01-19-2012, 12:49 AM
  #120
Here's my SSC LCG gt8 lite. The electronics are NOT mounted down in this pic.
Front shock tower in the rear as suggested. Running stock front shock up front, traxas metal bodies in the rear. The rear arms pretty much bottom out at neutral, the fronts travel just slightly below level. I'm more curious as towhether it's worth limiting the UP travel just a bit, or do I need to leave it alone? Will the revo shocks make that much of a difference?
