how to calculate rollout >
Old 10-12-2004, 06:56 AM
Talking how to calculate rollout
hi guys
Can anyone please help me on calculating roll out.
Thank you
Newbies is offline
Old 10-12-2004, 07:00 AM
JDXray's Avatar
i needed help on this one too. But this is what i got outta the forums.
RBLove wrote on Today 04:52 PM:
Yeah No problem.
19turn actually take a bigger gear than stock. Tire size has everything to do with it. I assume this person is running on carpet?
Tire size x pie (3.14) = ______
Spur / pinion x internal gear ratio = ______
Divide the top number over the bottom and you have roll out. Do not flip these two when dividing..
Example: X-Ray FK with 2.25 in tires ( I do not use mm).
2.25 x 3.14 = 7.06
132sp / 35pin x 1.77 internal = 6.67
7.06 / 6.67 = 1.058 roll out
Depending on track size, but like Cleveland or Snowbords a monster stock would be geared around a 1.00 or little lower. 19t would be at a 1.12 or even higher.
Hope this helps......
Rob
JDXray is offline
Old 10-12-2004, 08:14 AM
Another way of crunching the numbers is:
(Tire size * pinion * pi) / (spur * internal ratio)
This requires division only once. It is also easy to pull out part of the formula and call it a constant to remove all need for division at the track.
(pinion * tire size) * (pi/(spur*internal ratio))
pinion and tire size are the only 2 things likeley to change so you can pre-calculate the right half.
Using the example numbers above you would just do
pinion * tire size * .0134
The easiest though is to just make a table, but real geeks do it by hand.
galway is offline
Old 10-12-2004, 08:20 AM
Chill Will's Avatar
www.gearchart.com
Click on gearchart creator. It has a section for rollout
Chill Will is offline
Old 10-12-2004, 08:31 AM
StewartFan20's Avatar
Default rollout
The question I have is....How do you know what the rollout should be for a particular track?
StewartFan20 is offline
Old 10-12-2004, 10:51 AM
PaZ
PaZ's Avatar
Default roll out
The best site i have ever used and found for roll outs is http://www.arroyoc.com/index.cfm?fus...utilities.gear you can print them out and take them to the track with you so you will always be able to check, like me
PaZ is offline
Old 10-12-2004, 12:43 PM
you don't really know what is the best rollout until you get your car out on the track. Rollout is jjust a useful measurement for holding a setup or trying to copy someone elses. So the best way to find out a good rollout is to ask someone good at the track what they are running.
galway is offline
Old 10-12-2004, 01:20 PM
johnnywhopper's Avatar
if you're figuring rollout for a pan car, there's no internal ratio needed, it's simply:
pinion x tire size x 3.14 / spur = rollout
if someone has given you a good rollout and you want to figure out what pinion to use, just figure it backwards:
rollout x spur / 3.14 / tire = pinion
jw
johnnywhopper is offline
Old 10-12-2004, 02:12 PM
So heres the roll out of my car ...
(66 x 3.142) (95 24 x 1.81) = 28.96 mm per rev.
neveo is offline
Old 10-12-2004, 02:50 PM
heres a easy one. roll out calculator
jasong is offline
