I F M A R starts or heads up
#46
Re: Everyones job
Originally posted by Silver Cup
Agree to dissagree TonyV
When you are driving a (major) event you want to, no need to, concentrate on driving your car. This makes you faster, makes it less likely that you go off and possibly most importantly less likely that you take someone else out. Talking definitely does not help your concentration nor anyone else's.
This is why in most national and international rule books there are rules governing speaking on the stand. In electric racing it is even not allowed for your pit man to call out and/or coach the driver. In gas powered racing that obviously would not work as the pit man at least has to able to call you into the pits.
The problem with this type of rule, like many others, is where to draw the line and how to maintain it. The more fancy you draw it, the more likely it will be unclear and lead to problems. (Check the Electric On Road WC thread with regards to IFMAR's body homologation rule and you'll understand where I am going with this ).
#47
Re: Re: Everyones job
Originally posted by tonyv
Sure, everyone's entitled to an opinion . I fully agree with you on the club level and even international level racing, IF this is the only thing that is talked about on the stand and doesn't lead to continuous talking.
#48
I haven't read all of the posts so forgive me if I'm going over old ground. The best starting method I have used is ifmar with a resort after each run within that heat to put the fastest car out first and the slowest out last. The problem I have been seeing in some races though is the gap between cars is way too long, sometimes almost 2 seconds. This means that the leader is passing the last placed driver on the second or third lap. if we go for a max gap of half a second, it is enough to spread out the start giving the lead car enough space to get into his rythm before having to pass anybody. No matter how much people like to see racing, qualifying is against the clock. Of course at a local club race it doesn't really matter but when you get to regionals and above it does get important.
#50
IFMAR - Heads Up a never ending debate. Or is it?
What we have seen is that newer drivers, that run at a club that uses IFMAR starts, never learn to start heads up for the mains well. I also personally feel even with IFMAR the cars starting up front get a better run, no cars to drive around for awhile. This might not hold true for A main type drivers but as you go down the heats it gets worse.
We had our first indoor race of the season last night and tried something different.
First heat standard IFMAR, 1 2 3 4 5 6.
Second heat inverse IFMAR, 6 5 4 3 2 1.
Third Heat Heads up.
Everyone gets to start towards the front, everyone gets two heats to get a good qualifying run, everyone gets practice for starting mains, and everyone seemed happy.
The best of both worlds? We'll let ya know.
#51
Do they have heads up in real race car quals? (not sure since I don't watch a lot of racing) Only in Drag racing that I know of.
hey mal, how ya been, long time no see. take care.
#52
#53
In the Netherlands the first heat is IFMAR according to starting number. The following rounds it is again IFMAR with the driver with the fastest time sofar starting first. This way you get the least possible need for overtaking as the fastest driver has the clear track and the slowest sofar starts last.
#54
IFMAR for the heats,a nd heads up for the main, that means if i am starting last cause i got hacked (happens lots) i have a better chance of getting my trade mark second place, or my almost never 1st!
