I F M A R  starts or heads up >
Like Tree1Likes
Old 10-07-2004, 05:47 AM
  #16
dr_hfuhuhurr's Avatar
Trader Rating: 93 (100%+)
I would say IFMAR typically but several of the places I've been have been really bad about having an "IFMAR" mentality and letting the faster car through.
I like IFMAR but if people aren't letting you pass, a Head's Up start may as well be used.
dr_hfuhuhurr is offline
Old 10-07-2004, 08:31 AM
  #17
Yeti35's Avatar
"I would say IFMAR typically but several of the places I've been have been really bad about having an "IFMAR" mentality and letting the faster car through"
That seems to be the thing with IFMAR that most people don't get it that it is against the clock not each other. I know when I first started it was hard mentally to just let other by but now that I have been doing it awhile it really makes sense.
We do heads up starts at our track for club races but IFMAR for big races and some of the people that just do the club races mainly don't get it right away. We have been using the transponders during club races to get the newer people used to it and how it works for big races.
Yeti35 is offline
Old 10-07-2004, 10:39 AM
  #18
Silver Cup's Avatar
Thumbs up Heads Up
Heads up all the way! Race for your qualifying spot and have fun. We run everything heads up and people like it alot. It seems boring to race the clock when qualifying, Let's RACE!!
achtung1970 likes this.
Silver Cup is offline
Old 10-07-2004, 11:26 AM
  #19
Company Representative
Tres's Avatar
Trader Rating: 14 (100%+)
Several of the local tracks have been doing heads up with resorts between rounds.
It helps a lot for the main.
The problem with IFMAR is when other drivers want to race you to hard for the position.
Tres is offline
Old 10-07-2004, 11:33 AM
  #20
howard hudson's Avatar
Default reminder
This is just a reminder that the question was for large races only ie regionals , champs, worlds, nats,or any other big race your track my be hoasting . Not club racing that should always be heads up qualifing.
howard hudson is offline
Old 10-07-2004, 11:36 AM
  #21
I see that more as a race directors fault . he or she should be calling traffic for the fast lap time cars and the drivers should listen and pull over enough to let them by.
Old 10-07-2004, 11:42 AM
  #22
Tres's Avatar
howard hudson: very true....
keyword is "should"...
Tres is offline
Old 10-07-2004, 12:17 PM
  #23
EricF's Avatar
Default Re: reminder
This should be the ony way for large races.
E.
EricF is offline
Old 10-07-2004, 12:35 PM
  #24
Vue Vang's Avatar
I think that ifmar for qualifying is a great idea. But I don't like the heads up start on the main, especially if there is a 10 car main on a small track. More than often there is always a big pile up at the first corner. After the race I'm always left with the feelings that qualifying means nothing when the start ends up like that only because everybody is fight for that first corner. If we are going to do heads up start we should have the cars in single file line and separate them far enough so that there is less chance of being taken out. Just my thought.
Vue Vang is offline
Old 10-07-2004, 12:40 PM
  #25
EricF's Avatar
Vue,
I agree w/ you, but single file seems a bit much, although I could see a staggered grid.
E
EricF is offline
Old 10-07-2004, 12:51 PM
  #26
Silver Cup's Avatar
Gotcha.....Our club racing is always heads up for sure. We have a big two day race every year and we just leave it the same.
Just in case some of you wanted a peek, here is our race report for or 3rd Annual Weekend Tournament.
Right on!! Keep havin' fun racing everyone!! Just drive with a
Old 10-07-2004, 12:55 PM
  #27
Silver Cup's Avatar
Talking Everyones job
What if a car your lapping is racing for position?? He has to maintain his position and should never just pull over for anyone. Isn't that what communicating on the drivers stand is for. I am a race director and there should be both. The cars being lapped should hold their line and the fast guys should be able to get by no problem. Between all the drivers on the stand communicating and the race announcer calling the action, it should be really good. The problem is not all of the above happens and it should.
Old 10-07-2004, 01:08 PM
  #28
Mal
Registered User
I disagree, the people being lapped should not hold their line. That's just asking to be taken out specially if you have to slow down and follow that car for serveral laps. I don't mean pull over either. If the guy is fast enough to put a lap down on you then giving a little opening for the inside line is enough.
I totally disagree on heads up. Qualifying is about who has the best line and who's most consistant. Qualifying shouldn't be who has the most luck passing back markers. If you make qualifying similar to mains, it just makes back markers more reluctant to give you room to pass. The racing should be done in the mains.
Do they have heads up in real race car quals? (not sure since I don't watch a lot of racing)
Mal is offline
Old 10-07-2004, 01:19 PM
  #29
Silver Cup's Avatar
Do they have heads up in real race car quals? (not sure since I don't watch a lot of racing) Only in Drag racing that I know of.
People do not always just move over in real racing either. I agree they should give you some room on an inside line so not to lose any ground they have made. When I was involved in racing real cars we had one qualifier and heat races then a trophy dash then the main. The qualifying was to see which heat you were in then the winners and the tope 3 or 4 from the heats ran a trophy dash then the main. The heats set us up for the main and then in some cases they inverted the top 3, 6 or 10 depending on how many cars there were. Your right about qualifying being about the best line around the track........Is it that bad to have racing for a position to have some fun with each other all day long??
I agree to disagree no harm intended by any means, just stating opinions as well.
Old 10-07-2004, 01:26 PM
  #30
Default Re: Everyones job
position? In IFMAR qualifing there is no first place or last place everyone is on there own clock ????? so there is only fast cars and slow cars. If your one of the slow cars you must yeild to faster traffic . there should be no battles for position at all.
