Team Losi JRXS
Originally Posted by slowsi18
I was wondering if anyone that owns a jrxs would be interested in buying new and improved parts for the car? I will be selling alluminum a-arms from and rear, pivot mounts. also will be selling rear hubs, also front spindles and carriers. interest pm me and i will let you know on details
You interested in having a team guy run your parts
I would love to see a set of front spindles with .030"-.050" shaved off the bottom...
KBs Rear Mod
Has anyone attempted to add a rear sway bar with this mod? Is there a way to do it without the sway bar binding between the bulkheads?
Thanks!
Thanks!
I have not.. but where there is a will, there is a way. I immagine if you just do a litte extra bending it will fit.. OR.. grind a little.
I think it is moot though as this mod adds a ton of steering.
KB
KB
Thanks!
Thanks!
Brant
I just got my JRXS a couple of weeks ago and am very impressed with the car! It fits my driving style much better then my FK05. I only have had 1 issue with the car though. One of my shocks keeps leaking and I've rebuilt and replaced everything but the shock body. Could the shock body be the cause of this? Any insight into this problem would be greatly appreciated!
I haven't had any JRX-S shock problem like that. Their shocks have been a dream.
I suggest that you get in touch with Todd Hodge at Losi via e-mail.
http://www.teamlosi.com/
Bill
If its leaking from the bottom then you may have a bad shaft. I had a bad shock shaft new out of the package a few years back on my Matt Francis I truck. There was just something out of round or something that kept it from amking a good seal. The shaft was the last piece I replaced and that stopped the leak. If your leaking from the top of the shock then I too suggest you contact Todd. Good Luck!!
Brant
Dang! PookyT may have something there...
I was shocked after he replaced the shaft that it was fixed...I felt bad because he just purchased the car, but now he has it running and he really likes it.
Well I guess you didn't fix it then yet did you Rob lol
I thought it was fixed once you replaced the shock shaft?
I will rebuild it for you at the track during the Meltdown. See if I can work a little miracle on it
Have you tried "green slime shock lube"
I find this stuff really good.....
Thanks guys! The shock leaks at the lower shock cap. At first I thought the shock shaft bushing was messed so I replaced it more then once and that didn't seem to solve the problem. I then changed shock shafts, and thought that solved the problem, but 2 races later it was leaking again. I'll be getting a new shock body at the track Friday to see if that will solve the problem. Thanks for all of the help guys!
I bet you can use some washers or aluminum stand-offs to space the sway bar mount out some from the tower. Hope this helps.
Brant
Brant
Cheers Malc THE CAN MAN
With the rear shock mod, to space the sway bar mount away from the rear tower use the following parts:
2x Stand-off
2x #4 Washers
Bolt the stand-offs to the towers. Use the #4 washers in between the plastic sway bar mount and the stand-offs. Insert the bar and mounting screws then tighten down.
2x Stand-off
2x #4 Washers
Hey Pookyt, you are not the only one who likes to modify things. This modification did not require a Dremel in anyway but it was fun non the less!! This is a pic of my 12Losi4 w/ a CRC dampner tube conversion as well as my own, untested at this point, battery retention system.
