Team Losi JRXS
#9946
Originally Posted by R/C Anonymous
very low bite is an understatement more like NO bite
#9948
Numan
I'd like to say good luck to Josh Numan and his new ride.
I find it ironic that the hot jrxs set up is basically called the numan set up, and he's now no longer a losi driver.
Good luck!!!
Good luck!!!
#9949
Good luck!!!
Good luck!!!
What are we to do now??? Where have they gone........the Darkside???
#9950
Good luck!!!
Good luck!!!
Was posted that way considering Josh's success at the Reedy in the Open.
#9951
What makes them leave?
#9952
ill give you an idea...if i dont get those steel outdrivesfor the TC3 for next weeks racing ill help you get your car faster if your wanting some help with it...i noticed a few things thatcould get worked on
#9954
Stuipd question here,
I am working on my car and I just tried to switch it over to using the offset hole in the rear arm with 0 deg hubs and its not working. The cvd appears to be to long and I cant get any negative camber at all, It appears as if the end of the cvd is binding on a screw and nut thats holding the dif together. Is there something I need to purchase to make this work or am I just doing something wrong?
Any advice would be helpfull.
#9958
I will start with the setup i was running at road rage, and put light springs on the front.
#9959
Originally Posted by J.Filipow
pballkid- You need the 'O/S' or offset hubs to run the offset hole on the rear arms. LOSA9854 is the part number for zero O/S hubs.
#9960
Originally Posted by pballkid21587
Another question that I have not been able to get a good answer for. What does the offset hub location do compared to the regular one? Any help would be appreciated.
Brant
