Team Losi JRXS
#4727
has any ones car been really twitchy when they first got it? if it was what was the fix?
#4728
#4729
Thank You
#4730
I can use the old C hubs on the new car right?
#4731
Yep, you'll need to open the opening a bit for the LCD's to clear...
Check out Rob Love's set up on JRXS.com it's been real good for stock and mod/19T...
KE
#4732
Im trying BK's set up right now but tomarrow ill try that one too.
#4733
hey kev or rob i am trying to finish rob love set up but bio didnt have 6* casters, or 1* rear pivot blocks , or 1* c hubs for rear also do you or rob have any that i can buy off you ???? or where else can i get them???
also what brand of ball stud are you using for the longer ones ???
what spring are you using i know the set up says 50lbs front and 25lbs but are they the jrxs spring or different??? and do you have any extra that i can buy ??
thanks
travis
p.s. i will be at the track toomorrow
thanks
travis
#4734
Regional Moderator
I just got to try the car in a more traction friendly condition and WOW!
I was convinced that I needed the sway bars, but I after this run with a little different setup, I don't think I need them as badly as I thought.
Can't wait till the next weekend to try it out on the track again.
And I reallly like the Skoda 2 body.
#4735
thanks
travis
thanks
travis
Use the new style AE studs for the TC4, the hex heads are dialed!
As for springs, Bob at Granview Hobbies has the 50LBS, but for tomorrow you'll have to run the stock ones, just stand the front shocks up a hole if you have too much steering, this will add dampning...Rob and I will be at WOH in Cinci tomorrow, Sorry!
Good luck!
KE
#4736
Battery Bars
What are the best battery bars for maximum chassis clearance? The ones in the Losi "Todd's Trick Tips" website look much flatter than the bars I currently have on my packsİ I am concerned about the bars touching the chassis during insertionİ Has this caused any issues for anyone else?
#4737
SMC gold bars work..
#4740
Originally posted by John Tag
Greg, Get to bed you have a lot of drying to do in the am, Just got your pm sorry I was at a wedding/funeral. I'll bring the book tommorow. I smell somthing bad,Oh no am I... Yup
What up Tag??
