Team Losi JRXS
#286
Re: Torque Steer
With the torque steer you guys are talkin about, it is due to the weak plastic outdrives on the diffs right? but if you look at the diffs on the JRXS, it seems rather different, the outside case is not actually the outdrives i think, but the casing. May be Losi has found a solution to the problem
#287
seaball - If the arm is half the length of a longer arm, it will take half the distance for the short arm to reach the same angle of the longer arm at twice the uptravel distance. Thus the car stays flatter with the same amount of camber change so in essence the car should generate around the same amount of mechanical traction but reaction times will be increased.
Yes you can counter this by a long camber link bit that is not the case on this car, links are short as well.
#288
Shocks
Hi,
You must have an IQ off 240 or higher
Thomas
Oil filled Coil Overs!!!!
Thomas
#289
David Joor- i can understand your explanation about the benefit of the shorter suspension arms, but i have something to ask, and it's about the shorter drive shafts. With the smaller shafts, a larger angle change will take place over the same distrance travelled, but wouldn't this make the drive shafts less efficient as it rotating at a larger angle? jus a thought
#291
BUt how is the angle of roll dictated by the amount of angle change? shouldn't it be the suspenion travel that affects it?
#292
Surely if the arm is at say angle X the driveshaft will be at angle X also whether the arm is long or short so it should have the same efficiency.
#293
The change is arm size will increase the speed of reaction but also increase the overall tension in the suspension which would need to be compensated with shock setup.
using moments the longer arm can get to angle x with more leverage and less energy than an shorted arm. However if the shorter arm had softer suspension the time to reach the angle would be quicker than the long arm and the suspension tension the same.
#296
Re: Short Arms
Originally posted by David Joor
rayhuang - Short arms are due to centerline weight of the battery, the car will not roll as much so the short arm is used to create the needed camber change for sidebite.
Thanks,
Ray
#297
Definitely should be exciting!
Short arms should work very very well on flat high grip carpet. It will naturally keep the suspension tight but make it very responsive.
Maybe AE should release a short arm mod for the TC4 for high grip on-road use. Better still I might design my own if I get a spare minute with a CAD program lol
#298
Also incidentally having arms this short isn't anything radically new. The Robitronic ETCv1 has arms about the same size.
#299
Re: Re: Short Arms
Originally posted by rayhuang
Thats what I was thinking-some big changes in suspension geometry would have to be done to accomodate the centerline weight.
Thanks,
Ray
Thanks,
Ray
