PRC Quad12
#331
Originally posted by Tim Stamper
All that I can say is that it is the best thing since sliced bread...slapmaster thrust setup. ...slapmaster ms2.2 ...Tim
thanks,
Eric
#333
happy new year doug!
#334
Moderator
Doug,
I just ordered the full Quad 12 2.5mm converison kit I had a rough last few days of racing, with a crystal die'n, and a servo die'n and on one freak out on the servo's last move was to send it into a wall and de-laminate the L3 chassis I had.... So I placed an order for a new servo (nice Futaba 9650 digital) and your quad 12.
really hope I can get the parts in hand by the end of the week so I can race!!
Cant wait!
Cant wait!
#335
Clegg I drive for doug if you need any help with set ups I can help you aswsell.
Welcome to the prc family you will indeed be happy with your chassis!
#336
Originally posted by Clegg
Doug,
Cant wait!
Doug,
Cant wait!
Your kit will ship today and will be personally delivered to you by an agent of the US Government.
Thanks for your order and stay in touch.
D.P.
#337
Doug how are those updates comming along?
#338
I have a couple questions for you guys
First what blocks are you using on the front end 0,5,10?
Second what spring and oil in the shock?
Last what postion do you have the batteries?
keith
keith
#339
kt I have 10 deg blocks with 35 wieght oil in the center shock with silver springs.
With the batteries in the rear.
#340
purple in front
gray in rear
carpet track using 19 turn.
how do the pink and double pink compounds work?
#341
doug,
Just wanted to comend you on the car. Love the battery system. So much better than putting tape on everytime.
keith
keith
#342
kt first off what t-plate do you have on the car and where are your castor shims also what is your ride hieght and what size are your tires!
Also what front springs are you using! and are you running any toe out?
I wouldnt use double pink for 19t unless it was a high bite track.
#343
I'll be out for a while. If you post a reply check back later! I am here to help you!
#344
castor 2degree
ride height 3mm
tires front 58.5mm
tires rear 59mm
#345
Moderator
Dude those tires are HUGE.
I think I keep mine at like 47mm at the most in front and 50mm - 51mm in the rear.
How much toe does the car have, negative camber, and have you put it on a tweak board to make sure the car is tweaked properly?
