WRC Racing F-One >
WRC Racing F-One
Like Tree19Likes
WRC Racing F-One
Old 09-13-2011, 02:22 PM
  #61
CFR
CFR's Avatar
Originally Posted by njt
Rear tyre - diameter 60mm ,width 43mm, wheel diameter 38mm
Front tyre - diameter 60mm , width 29m , wheel diameter 38mm
14mm hex
2 cell lipo and Team Powers 21.5 motor
Cheers Nick
21.5 much the same as G2 on LiPo I believe
Originally Posted by Cartman
glenn njt is nick t front rcracechat if you dont know
I know that
nick did his same as mine glen
I know that too, he's posted the pictures
CFR is offline
Old 09-16-2011, 08:34 AM
  #62
njt
njt's Avatar
Great ideal you had and glad you shared it,this has made a big improvement to the F-ONE handling
I do know who every one is
njt is offline
Old 09-17-2011, 08:55 AM
  #63
njt
njt's Avatar
Another option part from WRC F-ONE camber adjustment
http://www.wrc-racing.eu/ricambi/ico/f-one091.jpg
njt is offline
Old 09-18-2011, 02:31 AM
  #64
bakaguyjean's Avatar
So what parts have you guys that run these broken yet? Or replaced because of wear?
bakaguyjean is offline
Old 09-18-2011, 02:39 AM
  #65
CFR
CFR's Avatar
Nick
post a picture of them in use if you have them as the small library picture doesn't help much
CFR is offline
Old 09-18-2011, 11:06 AM
  #66
njt
njt's Avatar
Thumbs up
No parts have worn out,
which is great new's and the only part that broke was the front wing, and that was caused by a T/C stopping on the straight and not giving a warning
The foam tyres have now completed in-excess of 360 laps at various tracks without being damaged
njt is offline
Old 09-18-2011, 12:00 PM
  #67
JamesHealey's Avatar
if you ran F104 tyres on this car would it bring it within the 180mm width?
I'm looking for a 180mm width car to race in the BRCA GP1 next year, my Tamiya F103 is ok for GP2..
JamesHealey is offline
Old 09-18-2011, 01:14 PM
  #68
The only real draw back is the wings to me,Have you ran it with a normal wing up front? Something that deosn`t attach to the front arms.
Old 09-19-2011, 01:56 PM
  #69
njt
njt's Avatar
I have only run the F-ONE with the kit wing, in my opinion no other after market wing would fit on to the top deck.
njt is offline
Old 09-19-2011, 02:04 PM
  #70
njt
njt's Avatar
Have no ideal , never owned a F-104 ,what i can tell you is the F-ONE is 190mm wide . why not try a F-ONE to RACE
njt is offline
Old 09-26-2011, 06:28 AM
  #71
CFR
CFR's Avatar
Originally Posted by CFR
Nick
Any pictures Nick?
How much camber change do they give?
Without them are the front foams coning?
CFR is offline
Old 10-12-2011, 12:10 AM
  #72
njt
njt's Avatar
Default camber link
Have received from WRC the camber link parts there are 4 items
the range off adjustment is 0 to 3 degrees, and have fitted the 2 degrees to my F1, I find this prevents coning on the front tyre.
Also it will help support the top deck
Attached Thumbnails WRC Racing F-One-new-camber-link.jpg   WRC Racing F-One-camber-link-plate.jpg
njt is offline
Old 10-12-2011, 12:15 AM
  #73
njt
njt's Avatar
Default F-ONE
In Radio Race Car there is a feature spread on the WRC F-ONE, 7 pages long
njt is offline
Old 10-12-2011, 03:11 AM
  #74
Hello I am interested in this car but donīt know the type/size tires it uses. Are they F103 size or F104? Or you can use booth tires without too much modifications?
I have seen one WRC One running Las Vegas IIC F1 using F104/RIDE rubber tires
Regards
rokosam is offline
Old 10-13-2011, 12:09 AM
  #75
njt
njt's Avatar
Regards
The F-103/F109 will fit onto the axles, don't know about the F104 ( never owned one)
The front axle is 5mm diameter and the rear is the standard 14mm hex found on most F1s
njt is offline
