Team Associated TC4
The pics URL leads to the site that stocks it but here's a direct link: http://www.end-of-line-rc.com/tc4-cl...20under%20body
Discontinued but not unavailable...
Is that the Diggity Designs one? #TC5-052?
The guy whos question I answered in the first place wanted to know where to get it... so I told him. Not sure why that bothers you? Also not sure why you act as if ordering from the UK is impossible? Both rhetorical questions, I don't care.
Back to your regularly scheduled TC4 thread...
Tc5-052 is the correct one....
The internet is global folks, just like BERT...lol...
Keep the tips coming Bert......liked the aluminum ball stud info. i need to get some advantage on my brother.....for diveway racing. Thanks.
Guys, only run the lightest tires available: Sorex 32jb(Tso-xg-32jb) $32.49.....24grams lighter than other tires...
Guys, I changed all my Novak motor screws from steel to titanium. Do you think the absence of steel will result in a stronger rotor magnetic field ??? I've yet to test that theory..
Thanks Bert.......good stuff!!!
PLEEEEEEASE for the love of hank don't encourage him berts advice is all non sense having a silly lightweight car does no good as its under weight for actual racing and having a car designed to be much heavier you end up chasing setups all the time as the geometrys and spring rates are designed for a heavier car.
I read somewhere that the magnetic energy prefers to accumulate in ferrous materials rather than air or titanium... So I assumed that titanium screws was the way to avoid that problem, on top of losing a few grams... Lots of top racers position their fans at least 10mm away from the motor because of intefering magnetic fields, so I might not be wrong...
.....I understand the point that when you get below min weight and setup chasing.
If i am not mistaken I have read many tips from Bert that didnt involve lightening the car. Ex.....sanding gears, a special type of lubricant, many tips that make sense and would work on any kind of car.
Bert......keep these good tips coming....I have learned a lot from you.
Lol........these guys dont want you giving away all their secrets to speed.
