Team Associated TC4
Adding to what Mopar said, the transmission ratio of a TC4 is 2.5, so you take the ratio of the pinion and spur (30p and 60s would give you a 2.0) and multiply it by the transmission ratio to get the final drive ration (2.0 x 2.5 = 5.0)
Why does it seem like nobody uses 64 pitch? It's probably easier to get big pinions in 64 than 48, and you don't need two sets to run pan cars and other stuff as well.
Thanks for the replies.
Here are the rules from the local track in Kansas City Fastlane Raceway:
TransAm
4WD TC chassis
4 cell NiMh batteries with ROAR approved 17.5 Brushless or 27t, 24 deg brushed motors
ROAR Approved 7.4v Lipo with Novak 21.5T brushless motor
HPI Vintage treaded tires and vintage wheels
1450g minimum weight
With that listed what are your suggestions for a motor/esc setup.
This is a newb question but what does the acronym FDR stand for?
TransAm
4WD TC chassis
Interesting rules. They seem highly modified from official VTA rules. Is that it all there is? If so, you probably want to confirm the ESC rules with the track. VTA provides a list of approved non-timing ESCs. If there is no ESC restriction, then it opens your options up a bit.
Hey Guys - Fixing up my tc4 and trying to replace the cvd (dogbone with only one end a dogbone) but cant figure out how to get apart the wheel assembly to get the cvd far enough out to get the pin off. Anyone know of a magic screw to make it come off? So far I pretty much only have the wheel off.
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Thanks!!
Associated has exploded views available online, and there's probably youtube videos of it as well,
I had my TC4 out to Lou's Speedway near London Ontario Canada for the second time and broke the 8 Minute Canadian Vintage TransAm Track record that I set first time out by just over a lap. I have a Diggity Conversion and Yokomo Shocks and Wippler Drive Shaft. All the plastic is stock Club Racer. I'm working on a second TC4 / Diggity for Stock TC.
I ran a Stock Chassis TC4 Club Racer a couple of times over a year ago (with Xray Plastic Shocks the only hopup) which won every CVTA Race it was entered in. These cars are extreme value.
Nice write up, but still alot of things that could have been upgraded to make even more of a difference: CF shaft, no seal Bearings, better battery(65+C), lightweight input shafts, hirosaka gears, ceramic balls, aluminum diff outdrives, aluminum spool, etc........ These little things add up to alot....
In performance and $$$
Well to get Performance you need to spend a little on the tc4 versus alot on the newer chassis out there... The tc4 is super cheap and won't need constant maintenance for years to perform: it's a win win situation !!!
