Team Associated TC4
#7786
Originally Posted by TPhalen
The chassis plate is 2.5mm, the top deck and spine plate are both 2mm.
Should be available as we speak.
#7787
Originally Posted by Grindog001
is there any difference in the chassis between the stock factory team chassis? I can see the changes in the new upper deck and spine but nothing looks different on the main chassis?
The hole for the steering is now a slot.
#7789
Well, the hole is not the ONLY thing....heh heh
It is made of a different material....something that allows more flex than the stock chassis.
"Is it a 2.5 mm or a 2 mm chassis ?? Or a different graphite compounds ??"
But my english is too bad
ARgh i want it now, in france we only use rubber tyres
#7793
Man...my tc4 is the best car i ever drove in a while...it just needs a better driver
#7794
The shape of the holes under the tranny cases are different.
That top plate is sexy. I dig the spine too. I bet that spine on a standard FT chassis/top plate would feel great on some rug. Makes me feel dirty for buying a T2.
- DaveW
#7795
i found the problem, the instruction manual for my tc4 had the same measurements for the front and rear camber tie rods, the instruction manual on the internet had a smaller measurement for the rods in the front. I adjusted it last night and it appears correct now...
#7796
What are some good shocks for the tc4?
#7797
The standard factory team ones work fine for me as long as you get the VCS2 shock kit ($16 I think in the US).
#7798
YEkim
#7800
I'm actually liking my car the way it is Worked pretty good last night....
