Ko Propo VFS-1 ESC >
Ko Propo VFS-1 ESC
Ko Propo VFS-1 ESC
Old 04-30-2005, 09:40 AM
  #766
berger's Avatar
The Rayspeed standard setting is
35
33
31
30
28
27
26
25
25
26
27
28
29
31
32
33
34
35
36
37
39
40
41
42
43
44
44
44
44
44
44
44
Power Save 2.3v
Throttle response 6
berger is offline
Old 04-30-2005, 03:59 PM
  #767
kartermdb's Avatar
Trader Rating: 15 (100%+)
anyone have good settings for 12th scale 4 cell 19 turn???
kartermdb is offline
Old 04-30-2005, 08:31 PM
  #768
S-T-R-l-K-E-R's Avatar
IMO the masami model VFS-1's settings is for a 1/12 car. ask around if they know what i programed into it.
S-T-R-l-K-E-R is offline
Old 04-30-2005, 09:28 PM
  #769
berger's Avatar
I was talking about this last night with a friend, the settings given on the named speedos if they are even correct will be fairly useless, no driver will drive the same as them, have the same motors and cells as them and race on the same track! So you might as well just grab someone elses settings, Hebiki has some good 27T and 19T ones i believe who is a bit closer to the "average joe" racer and will have similar sorta gear (I know my promatch cells have similar numbers to his not [not counting your new ones ] and motors from EA) so it will be more suited to what you can use.
Try the KO Propo site for some 12th scale settings?
berger is offline
Old 05-01-2005, 01:20 AM
  #770
Hebiki's Avatar
Trader Rating: 26 (100%+)
let me know if you guys need help. berger knows my AIM. or PM. i got a new profile for 19T... but i gotta test it on a bigger track. should be real good.
Hebiki is offline
Old 05-01-2005, 01:45 AM
  #771
berger's Avatar
For 19T im sure just taking a 27T profile and adding say 7 to each step would work, then if you werent cooking the motor lower it from there until you got somewhere that you were comfortable with.
berger is offline
Old 05-01-2005, 02:47 AM
  #772
F. Alonso's Avatar
Enough of this 19t and 27t crap (only joking ) has anybody got any ESC setups that they use for Modified?? I'm currently using Hara's worlds setup and its okay... I might need to tinker with it for my own style a bit more.... just I was wondering what other people had tried and were racing.
F. Alonso is offline
Old 05-01-2005, 08:11 AM
  #773
Spud_J's Avatar
I'd second that, more low wind mod setups please!!!!!
i was under the impression that the standard setting in the Hara twister 2 was the setup he used at the worlds but not so. I was having problems with runtime on the standard setting but the worlds setting is an average of 4 steps higher and with a 120amp current limit. I guess the worlds setting is a reasonable place to start with it???
Spud_J is offline
Old 05-02-2005, 02:37 AM
  #774
Trader Rating: 17 (100%+)
hi can anyone tell me the ko shotki diode double(45516) voltage rating and amp. tq.
EngTat is offline
Old 05-02-2005, 05:14 AM
  #775
ernestf's Avatar
Hi
May I ask if anyone of you know the pin-assignment of the VFS-PC cable (RS232C to 3-pin) ?
Thanks a lot
Ernest
ernestf is offline
Old 05-02-2005, 08:16 AM
  #776
rc-zombies's Avatar
Originally posted by ernestf
Hi
Thanks a lot
Ernest
if you're trying to build one...don't try it.. you'll do more harm than good. there are circuit board inside the 9pin connector.
rc-zombies is offline
Old 05-02-2005, 07:04 PM
  #777
ernestf's Avatar
Thanks for your advise ... I am looking for either the PC-link or the adjustment unit for the KO VFS2000 ESC ...
ernestf is offline
Old 05-02-2005, 07:17 PM
  #778
hi there wat criteria should i select when getting a scoti diode??? higher amp or higher voltage???
100v 3 amp or 400v 3amp??? tq.
EngTat is offline
Old 05-02-2005, 08:28 PM
  #779
Hebiki's Avatar
simon.. why not just take my profile.. and add 32 stages to the whole thing? same concept
Hebiki is offline
Old 05-03-2005, 01:59 AM
  #780
over gear's Avatar
Trader Rating: 18 (100%+)
just got a VFS1... anyone got pic of the VFS1 in a 415MS? i want to see what's the cleanest way to put everything... the cap is hugh!
over gear is offline
