Serpent S411
#6813
http://www.petitrc.com/index.php?/setupsheet.html/
#6815
I'm trying to play with different camber link lengths and roll center adjustments but the stock camber track rods are too long to use the inner sets of upper link mounting holes on the rear. Is there a shorter turnbuckle than the stock 3x26mm or is there a shorter ball joint that will work?
#6816
#6817
17.5 Setup
Lap times, races started at 19:34:32
mylaps.com/en/practice-results/activity/677790945
Haven't reached post limit to post links yet LOLOL, C/P url above.
Forgot to add: Using Team Associated 6.2 CVD Blades for spool, they last longer than the Serpent blades. The blades have to be filed a little on each side to fit into the spool drives.
#6819
#6820
I appreciate your voice. I find it curious that i have only broken rear XH arms. I still have mediums on the front and have taken some pretty hard front and T-Bone hits that i just knew had caused some serious damage, but none received on the front end. It has been alot colder than normal here, around 50 deg outdoors, so maybe the XH arms are more susceptible to damage in colder temps...
#6821
Don't think so, they are very hard, you can hear the difference in them just tapping them, very high carbon content and very little give to them.
I've only had one set, and of that I broke one front arm eventually, although it would be questionalble if a hard arm would have broke as well. In any matter I use the hard arms, and like the way they work.
#6823
This setup worked pretty well for me on medium bite carpet. Should be a good starting place. Let me know how it works for you and I can probably give you some ideas to improve it.
