Like Tree16Likes
Serpent S411
Old 08-22-2012, 04:54 PM
  #4066
TJames987's Avatar
Trader Rating: 11 (92%+)
You use front gear diff instead of spool for rubber tire?
Originally Posted by red7fifty
S411 SE, box stock, great starting point for carpet. Running dual gear diffs.
TJames987 is offline
Old 08-25-2012, 02:34 AM
  #4067
Toughbeard's Avatar
You can but we usually use the Spool.
also for a wide range of parts available cheap you can check our web site:
http://www.evilhobbyshop.com
Toughbeard is offline
Old 08-25-2012, 03:54 AM
  #4068
TimPotter's Avatar
Trader Rating: 15 (100%+)
got the S411 Sport in the mail yesterday. I will post some pics of the build. I am going to get this kit working in 17.5. I have been looking for a GOOD inexpensive kit to get new people racing. It's showing some real promise, and some parts I am going to put on my car as well....
TimPotter is offline
Old 08-25-2012, 06:09 AM
  #4069
Toughbeard's Avatar
I sold my old car, so I am going to build a new TE to run at the ETS races. We will use the new plastic spool and the plastic sway bar holders to save weight.
We will build a Sport and test the car at one of the race tracks so people can actually see how it drives, but I am sure it will be very close to TE.
Old 08-27-2012, 01:14 AM
  #4070
Holmenkollen's Avatar
I bolted on the V2 motormount but it seems that it doesn´t align straight. With motor and pinion on the pinion isn´t 100 percent straight against the spur gear. With this the spur won´t last many runs. What´s wrong?
Holmenkollen is offline
Old 08-27-2012, 01:41 AM
  #4071
Toughbeard's Avatar
loosen all the screws and start to tighten then slowly but not fully in one go. if still not straight check the counter sinks thet the screws go in and check your screws.
also is the motor mount new or used. if used, check to see if its straight. I did bent mine after my crash in ETS
Old 08-27-2012, 04:56 AM
  #4072
Geberit's Avatar
I see some set-up's with 1.2mm ARB rear on the outer position! Is this a Serpent ARB or from some othe brand? Can't find a long 1.2mm Serpent ARB on their site …
Geberit is offline
Old 08-27-2012, 05:10 AM
  #4073
Toughbeard's Avatar
401496 1.2 mm ARB rear
we have it in Stock. 2.55 Euros + shipping 4*7 days air registered mail 4 euros
Apperantly I forgot to update the website as many of the new parts dont show up... looks like major update time for me...
Old 08-27-2012, 05:24 AM
  #4074
TryHard's Avatar
basically what he said... I tighten all the screws nip tight, then full tight, but in the following order... rear, front, middle, when looking underneath.
HiH
Ed
TryHard is offline
Old 08-27-2012, 08:08 AM
  #4075
Default Diff leak
Hello guys,
Does anybody has been facing some leak problem with the 411 diff ?
Since the begining, the oil keep inside for the maximum 5 packs.
Any sugestion to avoid it ? Any modification I have to do ?
Cestaric is offline
Old 08-27-2012, 01:28 PM
  #4076
Johnny Wishbone's Avatar
Originally Posted by Cestaric
Hello guys,
Use some AE green grease on the o-rings when you assemble it, that usually helps with leak problems. The rest is "as per" the instructions.
Johnny Wishbone is offline
Old 08-27-2012, 01:35 PM
  #4077
I think that the bars all come long now, with no part number change, but it depends on whether or not the stock is old or new from who you order it from. The outer hardware attachments, I have not seen anything posted by Serpent, so I'm assuming you have to come up with your own deal.
Old 08-27-2012, 01:40 PM
  #4078
If you get a chance, try this shock setup, 6 hole, 1.3mm with 2k oil. Really liking the feel of the shocks with this setup........seems good for all surfaces.
**Use the stock shock shaft spacing, but if you get into the lowest hole on the tower you may have to adjust the shaft spacing to compensate for the piston location.
Also if your running on carpet, try the 2.5 chassis with the 2.25 upper deck.......well worth the change.
Old 08-27-2012, 01:52 PM
  #4079
cwoods34's Avatar
I have used the XRAY long swaybars with success on the car. I haven't actually tried the longer mounting position on the arm, but they should fit!
cwoods34 is offline
Old 08-27-2012, 02:01 PM
  #4080
Yes, definately the Xray bars will work, and give the "in between" measurements if your so inclined. Good info though. Thanks
