Novak smart tray >
Novak smart tray
Novak smart tray
Old 11-29-2004, 02:48 AM
  #61
F. Alonso's Avatar
I don't know if excessive heat will really effect the Smart Tray that much. I was discharging some batteries with a bit of charge in it and the ambient temperature was 34 degrees. It was baking, but it was all good.
F. Alonso is offline
Old 11-29-2004, 04:03 AM
  #62
JDXray's Avatar
ya alittle heat it fine, and if you do put a pack on that has alot of charge and the heatsink in the back gets hot you should let it cool alittle until next pack. But i have never had a problem yet.
JDXray is offline
Old 11-29-2004, 10:12 AM
  #63
Charlie O's Avatar
When and how is the best way to use the smart tray for best voltage and runtime?
Charlie O is offline
Old 11-29-2004, 10:46 AM
  #64
AJ Racing's Avatar
hi ppl
is it good to use the smart tray before every charge or this would demage the battries
regards
AJ Racing is offline
Old 11-29-2004, 01:03 PM
  #65
JDXray's Avatar
You should tray your packs before charging so they get its full charge, I usually tray,charge,run, and then either discharge or put them away until next time and then discharge and tray before charge again.
JDXray is offline
Old 11-29-2004, 07:04 PM
  #66
Charlie O's Avatar
Thanks guys!, thats what i did, i left what charge was in them after the races from the week before, then discharged the packs down to 5.4 the day before race, on my quasar pro, then an hour before each heat trayed them, and then charged them.
Old 11-30-2004, 02:41 AM
  #67
VenomWorldOrder's Avatar
battery prep is the key people!
i failed to prepare my cells last race meet due to a night out the day before and didn't finish a heat without my packs dumping. i run a brushless and this never happens. discharge the night before on the novak tray down to 0.1 then get to the track early and charge the packs on the day there, then peak them 5 minutes before.... perfect packs.
VenomWorldOrder is offline
Old 12-25-2004, 09:31 AM
  #68
i got my smart tray from HK about a week ago i didnt open it as it was a christmas present it was poened today and the power lead connector is too small for the unit. it was factory sealed and wrapped in selophane! As im in the UK do i contact my distributor?
Dan Hughes is offline
Old 12-26-2004, 01:33 AM
  #69
No, Have a read of the instructions on the box and this thread. Either solder connectors on the pigtail to connect to a 12v power supply or pick up a 12v power pack to power the unit at home.
All the International version Smart Trays are supplied with a pigtail rather than a (useless outside the USA) 110VCD Power Pack. But thats all on the box...
v0rtex is offline
Old 01-26-2005, 04:54 AM
  #70
Losiho's Avatar
Yep, I picked up the International Version (#4501) from Singapore, and the input plug attached to that pigtail wire will NOT fit into the plug on the right hand side of the tray.
Does anyone else have this problem, and what did you do to fix it ?
Losiho is offline
Old 01-26-2005, 08:00 AM
  #71
Charlie's Avatar
Hey Guys,
Just send us an email if your Connector doesn't fit, we have a replacment we can send out.
If you guys ever have questions that need fast answers feel free to give us a call, or drop us an email.
[email protected] or
[email protected]
Charlie
Charlie is offline
