GEN Ace LIPO Batteries
#154
I have five GensAce packs (three 40C and two 50C 5000mAH 2S) and so far they have faired well. The 40C are of especally high quality but the 50C's have been problemetic. Both of them have to be constantly balance charge, each has cell with a higher resistance than the other and neither pack has been abused.
#155
Does anyone know when the 4s are going to be back in stock?
roc
roc
#156
Well.... I bought a couple of the 5000mAh 40C packs back in November for use in a USVTA car. One of them just ballooned up while charging. The official response from tech support (live chat) was that it's out of the warranty period (30 days) so I'm out of luck. I think next time I'll go back to the brands I've been using and pay twice as much, since they seem to last at least 4x longer.
#158
Having issues with my 5800 45c pack. It wont take a full charge, the charger is saying its full at less then 8.3v. At the moment its trying to balance the pack. As it apply's a small amount of current the voltage goes up to 8.38, but once the charger drops the amps back down to 0 the pack returns to 8.3v. At the moment its at 100mins and still going, it wouldnt balance over the weekend, so I pulled it off charge and ran it. Still no luck getting it back to balance.
#159
It could very well be an issue with the battery, but it might just be the charger. If you have a friend with an iCharger, a Thunderpower charger or a similar high end charger, see if they can balance charge your battery for you.
#160
Idbdoug
#161
Which charger? I had a venom pro charger that did crap like you are describing. I got a better charger and haven't had an issue since.
#162
So I was trying to balance it yesterday, by moving to a different port on the charger it got to 8.4, but still won't balance. On the multi meter the pack measured 4.19 and 4.25.
The second port doesn't drop to 0 like the first, but after 170mins it still wouldn't balance. Every time I bring it back down to about 7.6v with the charger in storage mode.
The charger I'm using is a thunder t6 multi.
I haven't treated this pack any differently then my others, which all balance fine. I was wondering if maybe 2s2p is more likely to fall out of balance then 2s1p?
